Got NAD? Crazy Doro's NAD Blowout
dorokusai
dorokusai Posts: 25,576
edited March 2007 in For Sale (FS) Classifieds
These are open box demo's that have exactly 24 hours in-store on them. I know they saw about 2.5 hours listening time as I was the one who set them up. As usual, too much stuff, so little time. All prices include shipping to CONUS.
I've been a fan since my first NAD rig was purchased from Russman. NAD gear is legendary for the Power Envelope, or as its called now...the Power Drive. This allows the amplifier sections to remain dynamically stable into 4 & 2ohms. The guts are straightforward and toroid based. The sound is warm, controlled and NAD easily integrates into any setup.
Take some time and read the reviews for the units, if applicable, on the NAD homepage and thanks for looking.
www.nadelectronics.com
If you have a question or comment, email me...dorokusai@comcast.net
NAD C320 BEE Integrated Amplifier - Grey - 9/10 - *SOLD* to Bill Ayotte
This IA and it's cousin the C325 BEE always get glowing reviews. The C320 BEE was chosen as the 2005 Hi-Fi Product of the Year.
As technology continues to evolve, NAD engineers place a particular emphasis on how those technologies can trickle-down into the entry-level line of components. This has played a major role in our success over the years as we continue to make what critics hail at the "best" even better. The concept behind the C320BEE was to create a simple to operate component that delivers an amazing amount of effective power with finesse and overall flexibility. Technologies found in the C320BEE date back to the famous 3020 (worlds best selling amplifier) designed by the famed Bjorn Edvardsen. The solid internal amplifier is stable down to 2-ohms and features the same PowerDrive™ technology found on even our highest-end offerings. With 7 line inputs, main amp inputs and pre-amp outputs, the 320 remains flexible with additional room to expand.
2 x 50W Minimum Continuous Power into 4 / 8 ohms
110W, 160W, 210W, IHF Dynamic power into 8, 4 and 2 ohms, respectively
PowerDrive™ amplifier technology
Headphones socket
High Current Holmgren™ Toroidal Power Transformer
Relay Input Switching
7 Line inputs, including two tape in/outs
All discrete circuitry
Short signal path from input to output
All sockets Gold Plated
Bass and Treble controls with Tone Defeat switch
Main-amp Input & Pre-amp Output
NAD Soft Clipping™
IR Input & Output
Full System Remote control including Stand-by/Off
12V Trigger Output
NAD C325 BEE Integrated Amplifier - Grey - 9/10 - *SOLD*
Check out the current issue of The Absolute Sound for a killer review of this Integrated Amplifier.
The C320BEE and its predecessors has been the benchmark for budget amplifiers for 30 years now, having won every award in the Hi-Fi industry several times over. Making the C325BEE better than the C320BEE was a tall order! By “trickling down” several innovations from NAD’s new state-of-the-art Masters Series products has resulted in the C325BEE having even less distortion, less noise, and a more detailed rendition of the musical recording.
New DC Servo eliminates sound colouring capacitors in the signal path. This improves musical detail and eliminates harmful loudspeaker ‘offset’.
Patented distortion canceling circuit uses both feedback and feed forward to reduce distortion and improve amplifier stability.
Highly optimised circuit layout further lowers internal impedance, improves grounding, and eliminates subtle magnetic distortions. Lower noise and distortion, and improved channel separation are a direct result of this optimisation.
Surface mount (SMD) technology shortens signal paths and lowers distortion in NAD's proprietary Class A gain modules.
BEE Clamp improves HF stability when driving difficult speakers.
Volume Control has minimum volume cancellation circuit to increase attenuation by 10dB.
Tone controls are hand trimmed for perfect response characteristics.
A new idling current circuit is more accurate with less unit-to-unit variation.
More rigid chassis has improved mechanical integrity.
MP Input for easy connection of iPod™, MP3 and other Media Players employing 3.5mm headphone sockets.
NAD T515 DVD/CD Player(+DVD-Audio) - Grey - 9/10 - *SOLD* to RCS
NAD’s DVD Players are renowned for superb performance and great value. Unlike the “no name” players sold as loss leaders by discount stores, NAD achieves picture quality that is impressive even on large format TV’s and projectors where every minute imperfection is magnified. Whether your TV is analog or digital the T515 is equipped to make the most of your TV’s performance offering both Component Video and HDMI outputs.
If the picture is impressive, the sound quality can easily embarrass machines costing 3 and 4 times the T515’s highly affordable price. Sonic performance on all audio formats easily rivals established performance leaders. Whether you are listening to CD or DVD-A, or even MP3 and WMA files, bass is full and taught, mids and highs are detailed and smooth, and the stereo image shows depth and scale. Over 30 years of audio engineering excellence is both obvious and reassuring.
T515 DVD/CD Player Features
Plays DVD-Video, DVD-R, DVD+-RW, VCD 1.0, VCD 2.0, J-PEG, DivX
Plays DVD-Audio*, CD, CD-R, CD-RW
Dolby Digital/PCM/DTS digital out
MP-3 and WMA decoders integrated (song titles displayed on video output)
Coaxial and Optical digital outputs
Auto switch from PCM to Bitstream
Audiophile quality 24 bit 192kHz DACs
6 x 14 bit Video DAC running at 108 MHz
Progressive scan with pixel-by-pixel processing for reduced processing artifacts
NAD T720 BEE Stereo Receiver - Grey - 9/10 - *SOLD* to gdpeck
NAD has always had a formidable reputation when it comes to high performance receivers, by combining our most popular amplifi ers with a high performance AM/FM tuner to make receivers with a genetic advantage. The NAD 7020, and more recently the NAD C740 have received world-wide accolades for their outstanding musical performance and superb value. As an encore, NAD is proud to present an updated version called the C720BEE. This combines our award winning C320BEE amplifier with an RDS AM/FM tuner, and includes a Multi-source Zone 2 facility that allows you to listen to your music independently in another room of your home by simply adding an amplifier and another pair of speakers.
C720BEE Stereo Receiver features
50W x 2 Continuous Power into 8 ohms
100W, 150W, 180W, IHF Dynamic power into 8, 4 and 2 ohms, respectively
PowerDrive™
AM/FM Tuner with 30 station presets
RDS data service for FM
Multisource Zone 2 with independent line level output
Speaker A and B switching
Headphones socket
Toroidal Power transformer
7 Line inputs
All discrete circuitry utilizing Class A gain modules
All sockets Gold plated
Tone controls defeat switch
Main-amp input & pre-amp output
Subwoofer output
Soft Clipping™
IR In & Out
12 volt trigger output
NAD T743 A/V Receiver - Grey - 9/10 - *SOLD* to Jim BRICK
The T743 is a popular choice for entry-level home theater customers who still want the very best in music quality and the ability to build on their system as their needs change. A true 5.1 surround receiver that offers the latest in digital processing formats while remaining intuitive to setup through the on-screen display and operate using the same HTR-2 learning remote found on our higher-end receivers. Maximize the potential of your entertainment through this compact and potent unit that offers six video inputs including High-Def compatible Component Video, S-Video and composite as well as sid digital audio inputs including Optical and Coaxial. Also found in this compact dynamo are premium-grade processors offering Dolby Digital, DTS, ProLogic II and other popular surround modes.
T743 A/V Receiver Features
5 x 50W Simultaneous Minimum Continuous Power into 4 / 8 / 2 ohms
105W, 145W, 165W IHF Dynamic Power into 8, 4 and 2 ohms, respectively
Dolby Digital, DTS, ProLogic II, EARS and Enhanced Stereo
5 A/V Custom Presets store unique speaker level and tone control settings
Direct access speaker level adjustment for surround, center and subwoofer
Stereo Bypass
NAD Soft Clipping ™
6 A/V Inputs, 3 with S-Video, 2 Full Tape Loops
Component Video, 2 Inputs and 1 Output, HDTV Compatible
2 Audio Inputs, 1 Tape Output
6 Digital Inputs, 4 Coaxial, 2 TOS Link freely assignable
5.1 Analogue Input (for DVD-Audio)
Speaker A + B switching (Speakers B stereo only)
2 x IR Outputs, IR Input
2 x 12V Trigger Outputs, 12V Trigger Input
Preamp Outputs for all 5.1 channels (2 Subwoofers)
Amplifier Input for 3 amplifier channels
RDS FM/AM Tuner with 30 direct access presets
HTR-2 - 8 Device Illuminated Learning Remote with Macro function
The units all have original remote control, original box and packaging and original user manual.
*The C720 BEE has a high quality reproduction user manual.*
I'm a bulletproof shipper and will double wall the inside of each box to ensure safe delivery.
033515TN
572B023CN
054347TN
054B027CN
Post edited by dorokusai on
«13
  • shack
    shack Posts: 11,154
    edited March 2007
    I can't believe no one has grabbed any of this NAD gear yet. What is it? 50 wpc @ 8 ohms? Don't let that number fool you...it is true continuous HIGH CURRENT power. I have driven SDA 1Cs to very loud levels with no distortion whatsoever with a C320BEE IA. I have personally owned the C320BEE and heard the C325BEE and T743 AVR and they are sweet! As for the DVD player, NAD is a company that concetrates on audio in their DVD players as much as video. The T515 would be a great dual purpose player for somone who wants good CD playback in their HT rig. I would be all over some of this stuff it I weren't already up to my eyeballs in NAD gear!
  • schwarcw
    schwarcw Posts: 7,357
    edited March 2007
    NICE! I am a big fan of their stuff! Great sound for a great price!
    Carl
  • dorokusai
    edited March 2007
    Thanks Shack Daddy :D I agree, don't let the low wpc mislead you as the amplifier section is solid. Adding to Steve's comment, I've also run a pair of SDA1C(Funny, but the SAME pair he now owns :), nicely on a 2240PE(2x40) and that amp is from 1987.
    The T-515 DVD Player also has HDMI output for you video nuts.
    I'm cleaning them all up, although they don't need it and wrapping them like little make believe babies....left to suffocate in their boxes this evening.
    For those of you on the wall about things, realize I can't match every internet price you're gonna find. Also realize that you're most likely not going to get a unit that is this nice and I hope you receive it working. When I say 9/10, low hours....I mean it, its not a guess. I take this shipping thing serious. I'm here after the sale, so there's nothing that we can't take care of.
  • JimBRICK
    JimBRICK Posts: 1,543
    edited March 2007
    Awesome stuff but I've spent WAYYY to much money this month
    2 CHANNEL
    Speaker - Klipsch Heresy II
    Under construction
  • dorokusai
    edited March 2007
    :D You feel good tho' don't you?
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited March 2007
    Yeah Shack, you always get at least a couple DB headroom with New Audio Dimension. Rock solid gear. I've run I don't know how many NAD amps and receivers - I have a NAD dvd-p anchoring my HT, and it has performed flawlessly for years.
    I hope this essentially NIB gear doesn't end up on ebay or audiogon, and some Polkies take advantage. I may have to buy one of the integrateds on principal alone.
    Cheers,
    Russ
  • audiobliss
    audiobliss Posts: 12,518
    edited March 2007
    This would probably be perfect if I were rebuilding my system...but I'm not there yet!!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • dkg999
    dkg999 Posts: 5,647
    edited March 2007
    I can highly recommend the C720BEE receiver! I've been using one for my bedroom system, and it sounds fantastic! It has a LFE out, so creating a sweet 2.1 system for movies and music is really easy.
    DKG999
  • dorokusai
    edited March 2007
    If anyone wants additional information, seriously, drop me a line anytime.
    I have the receipts for this gear so while I cannot guarantee the 2 year warranty, after my conversation with NAD today, I'm sure that if anything happens you'll be just fine. Let's talk.
  • George Grand
    George Grand Posts: 12,258
    edited March 2007
    If I was a hot babe I'd let you be my boy, for maybe one season. Wanna talk more?
  • dorokusai
    edited March 2007
    You had me at hot....<whispers and holds hand telephone to ear> Call me.
  • hoosier21
    hoosier21 Posts: 4,415
    edited March 2007
    I would talk to him about these pieces to Mark , but I am a babe on the rag
    he has no use for me
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • dorokusai
    edited March 2007
    I have my redwings honey.
  • pearsall001
    pearsall001 Posts: 5,234
    edited March 2007
    Great NAD stuff at a great price Doro!! Somebody will snatch them up. If I didn't already have the T773 (superb!!!) receiver I'd be all over this deal.
  • hoosier21
    edited March 2007
    redwings waaaaaaaaaaah
  • strider
    strider Posts: 2,568
    edited March 2007
    I may be interested in the C325. I'll send you an e-mail to discuss.
    Wristwatch--->Crisco
  • dorokusai
    edited March 2007
    OK, thanks Strider.
  • Demiurge
    Demiurge Posts: 10,874
    edited March 2007
    Using the money to buy new carpet? :p:p:D
  • marker
    marker Posts: 1,084
    edited March 2007
    I just want to point out that the little T743 AVR will drive a full ensemble of LSis with no problems at all in case that would fulfill a need for someone. ;)
  • danger boy
    danger boy Posts: 15,722
    edited March 2007
    very nice NAD gear... wish i could take one or two of them off your hands.. but i'm saving up for a tube headphone amp.
    good luck with the sale.. hope someone on here ends up with them.
    PolkFest 2012, who's going>?
  • dorokusai
    edited March 2007
    Demi - Nope, that male enhancement I've always dreamed about.
    Marker - Great comment, thanks much.
    DB - A HA sounds like a pretty cool idea to me :)
  • dorokusai
    edited March 2007
    The NAD DVD has left the building. Thanks Rob(RCS)! :D
  • strider
    edited March 2007
    I'm bowing out on the C325.
  • dorokusai
    edited March 2007
    No problem, good luck in your SDA project.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited March 2007
    I got mine by accident in the mid 70s .. . .:eek: and yes they do look like red wings, one on each cheek.:eek: :p:p:p:p:p:p
  • hearingimpared
    edited March 2007
    I just bought the T 773 or else I would be all over this like stink on ****.
  • dorokusai
    edited March 2007
    I just squared away the warranty issue as well...consider them covered baby :D
    The C325BEE is *SOLD*
    heiney9 Posts: 25,404
    edited March 2007
    Dibs thru the weekend on the C320BBE per e-mail with Doro. If someone has cash in hand or has a real need I'll defer.
  • shack
    shack Posts: 11,154
    edited March 2007
    THANK YOU....THANK YOU...THANK YOU!
    I've been avoiding this thread because this little voice kept saying "You miss the C320BEE...buy Mark's!". More gear is NOT what I need.
  • dorokusai
    edited March 2007
    :D Come on man...let's work something out with the other stuff....or some nice monoblocks :D
