Green display on POLK XRt12 XM Tuner Video
symphonic
Hey there,
I work for a av systems integrator company and we have used the XRt12's quite often. Recently we installed a unit, and following several days of normal operation, the video display went all green. So fair enough, Polk replaced the unit, and again the new units display has turned green as well. We've tested it with many different scenarios both at the customers house and the shop, and eventually after some time the screen becomes green again. Has anyone found the cause or a solution to this problem?
Thanks.
Thanks.
Post edited by symphonic on
Hi Symphonic... when you say you tested it at the house and at the shop, I assume you've tested different TVs. If not, that would be the first test I would complete. Could you take a picture of the TV screen to show the problem? Thanks!Brian Knauss
ex-Electrical Engineer for Polk -
Could it be a problem not being power cycled, since it happens on a couple units in a couple different areas?
Just wondering?
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
The area which is normally displayed black, is bright green and the station text is hardly legible and the polk logo is pink.
