Replacement tweeter for an RTi35?
rcs
rcs Posts: 21
edited March 2007 in Troubleshooting
What's the model # and price for a RTi35 tweeter? I keep seeing these bookshelf speakers out there with blown tweets....
Primary: SDA-SRS 2 (front), CS-350LS (center), RT35i (sides)
Secondary: RT-16
Fondly remembered: SDA-1Bs (1987-1991)
Post edited by rcs on
  • shack
    shack Posts: 11,154
    edited March 2007
    There is no such speaker as a RTi35. There is a RT35i which would use the tri-lam tweeter part # BD0125-W which is no longer made or available from Polk. There is a replacement soft dome tweeter part # RD6514-3 which will fit. There was a RTi38 which uses the soft dome tweeter mentioned above. Polk still sells the RD6514-3 tweeter and it is around $70 with the Club Polk discount as I recall.
  • rcs
    rcs Posts: 21
    edited March 2007
    Cool - thanks for the info, shack. I'd have to replace both tweeters, then, which increases the price significantly. I think I'll keep holding out for intact units.
    Here's the speakers in question, anyway: http://cgi.ebay.com/POLK-AUDIO-BOOSHELF-SPEAKERS-RT35_W0QQitemZ270098790341QQcategoryZ71572QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
    Secondary: RT-16
