RT series is bright as the sun...with no shade
So I removed my shade, err, I mean subwoofer.
And the sunlight came full bore from my RT speakers.
Never in my life have I heard such a forward presentation.
The bass is pretty good though at the same time. Not near enough to keep up with the top end. Definitely not a very balanced sound.
A subwoofer really alters your sound. Thats for sure. Its like immediate fatigue right now around here.
Im gonna go drain the blood from my ears.
Post edited by VR3 on
if your ears are bleeding from the RT series.... there is something else wrong with your system, and prob not the speakers. just my .02PolkFest 2012, who's going>?
Well they werent bright with a subwoofer.
Who knows....
Im just saying... *ouch*- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
If the Odyssey is bright...
then
Did you try them with the Crown amp, without a subwoofer?polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
It's probably the crappy source components you have :rolleyes: The RT/RTi series has a bright and forward top end, but it's not that bad. Good thing you don't have Klipsch! Maybe you need some of those old BBC voiced speakers from England, they all sounded like the tweeter was in the next room :eek:DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
The Odyssey is VERY neutral. Adds nor takes away anything. Its straight lace power.
The Crown is bright as a ****. You gotta decrease the treble -6db WITH a subwooferon.
I think alot of it has to do with the tweeter height, its about 2" above normal and thus seems to diffuse the treble into a mess. Very forward sounding, without a doubt.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I'll say the wood floors are an issue.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Now thats definitely a possibility...
I definitely need to get a rug.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
disneyjoe7 wrote:I'll say the wood floors are an issue.Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
Like I said, probally need a rug...
The Tweets were a little more doable with the sub evening out the sound....
Remove the sub and those highs really started to "shine" hehe...
Curious to see how the Ty's work without a sub. Should be here next week, I hope!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I removed the B&K from the mix...
Its a shame I need a preamp.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
So - The B&K is up for grabs then?
I also think you need a rug.polkaudio RT35 Bookshelves
those 55's were allways a tad forward. great for movies, not so much for music in my eyes but I never found them unlistenable. must be a perception thing since your rig has changed drastically with the removal of the sub.
like I said, theyre a bit forward, but I never found them THAT bright.Living Room 2 Channel -
Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
Upstairs 2 Channel Rig -
Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites -
for a music only system I have rti8's and a harmon kardon 3480 stereo receiver. I like to listen to music loud and the 8's are still harsh on my ears. The treble is not even turned up a quarter of the way, I really cannot take it anymore and am thinking of selling them...
640 bucks anyone? Brand spankin new...not a mark -
Hrmmm my RT400s are not bright but pretty neutral to warm,I guess it has to do with the processor and amps.My gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool:
