M200t problem....
Bill Ayotte
So, after looking at the photos that Opus provided, I am kind of dumb-founded. I figured the previous owner of this amp crossed a wire somewhere causing the amp to do this. When I turn the amp on when it is cold, it pops the protect circuit for about 5-10 seconds, then sends a pop through the speakers and operates as advertised. It is dead silent in operation, it even sounds better than the M400t I had redone my Rita at Carver Service. The only thing I can tell has been changed is the red amplifier on light has been changed to a blue one that matches the Sunfire color. Does anyone know what this could be?
Post edited by Bill Ayotte on
hey bill you want to edit that. Makes it sound like I broke it:DThe Flea rig
Hitachi 50VG825 LCD
Rotel RSP 1066 (pre) -flea market
B&K St-202 (mains)-flea market
Carver M 200t (x2) (center and surrounds)-flea market
Blu-Ray..PS3 (dvd player)
Polk RTA-11t-flea market
LsiC, Fxi30's
Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
Behringer Feedback Destroyer-flea market
AudioAlchemy DDE v1.0 DAC-flea market
Cambridge Audio Azur 640 CDP-flea market
Signal Cable and Kimber Kable -
Sorry man, I edited the offending sentence. :cool:
Bill, when you say it pops the protect circuit for 5-10 seconds do you mean you hear a relay chattering?Testing
Testing
Testing -
No chatter, the protect light comes on for 5-10 seconds, then the pop through the speakers, like it has an internal power surge at first, then goes to normal operation.
