New advice on center channel with SDA SRS
wrich22
I just put my new SDA SRS's in service using Dual Halfer DH-500's, my center
channel is a CS350LS, powdered by a DH-220 bridged amp. Pre-Amp Processer
is Rotel 1068. Is the CS350LS a good center channel match for my SDA's?
The CS350LS appears to be dwarfed sitting next to the SDA's. What is everyone else using?
Thanks,
Bill
Thanks,
Bill
Post edited by wrich22 on
With mine I use a pair of cs40is. One didn't seem to get it done very well. The pair works well. I run them off of one stereo amp. 200 watts for each seems to do the trick.
Phil -
I have a CS350LS with SDS-SRS IIs all powered by a NAD T752 and am enjoying it; granted, I am a complete HT neophyte and haven't heard any "reference" rigs to compare mine to. The fronts and centers seem well-matched to me in that their output blends well (i.e. the soundstage is even during complicated scenes containing dialog, music and FX) and I am impressed at the ability of the SRS IIs to handle the low end without a subwoofer assist. I plan on adding sides (RTi38s if possible) and might go back to using a NAD 2200 to power the fronts if the T753 sounds like it could use a little help.
Interested in hearing any feedback as well.--
Primary: SDA-SRS 2 (front), CS-350LS (center), RT35i (sides)
Secondary: RT-16
Fondly remembered: SDA-1Bs (1987-1991) -
Phil Dawson wrote:With mine I use a pair of cs40is. One didn't seem to get it done very well. The pair works well. I run them off of one stereo amp. 200 watts for each seems to do the trick.
Phil
I use a pair of LSi9's with the SRS's. Like Phil, I found that one center didn't work very well.Proud and loyal citizen of the Digital Domain and Solid State Country! -
What about an SDA CRS? I always assumed the 'C' stood for center, but I could be wrong... maybe it stands for compact or something. Either way, one of those should be a good fit.
I use a pair of 4 jrs on mine , 4.6's would be better or 5 jrs:cool: " He who dies with the most equipment wins Right ? "
Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center,HPSA-1000 18" sealed DiY home sub.:D
Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables -
dane_peterson wrote:What about an SDA CRS? I always assumed the 'C' stood for center, but I could be wrong... maybe it stands for compact or something. Either way, one of those should be a good fit.
CRS=Compact Reference System.Proud and loyal citizen of the Digital Domain and Solid State Country! -
Right on, thanks for the clarification. The SDAs were probably developed before center channels had really gotten off the ground, anyway.
Either way, I would bet they would blend pretty well as a center. -
That's why I'm on the look out for a pair. dual crs center hell yeah. Then I can get a set of srs's or 1's and move my 2's to the rear, then after all that is said and done set of old monitors for side surrounds.
I used a pair of CRS+'s as centers for a while, then I switched to using two LSiC's. I only switched because I did not like the bulky look of the CRS+'s above my TV.Proud and loyal citizen of the Digital Domain and Solid State Country!
I started with a CS350 (good), but ended up going with a CS400 (better), and wound up adding a second 400 (better yet).
The 400 was a bit fuller sounding than the 350.More later,
Tour...
Vox Copuli
Hi Bill,
Originally I used a single CS400i center with a pair of SDA-1C mains. It was a very good timbre match for the 1Cs, but not perfect. I switched to a pair of stacked SDA-CRS+s. The matched perfectly and filled the large sonic hole between my widely spaced main speakers.
Larry -
Larry,
That is a sweet setup.
engtazengtaz
I have a CS2 center channel speaker. Any thoughts on how they work in conjunction with SDA's?
engtazengtaz
I just replaced my Klipsch center with polk's LSiC to go with my 1.2tl's. The improvement is very obvious.Home Theater
Amp: sunfire cinema grand signature 5ch 425 wpc
Side surround amp: Sunfire 2 X 300
Processor: sunfire theater grand V
Fronts:: polk sda-srs 1.2
Rears: Polk LSiFX
Side surrounds: Fxi5
Center: (2)polk LSiC's
Sub: svs pb-13 rosenut
Hd-Dvd: toshiba xa-2
Blue Ray: oppo bdp83se
Projector: sony vw60
Screen: Da-Lite 106"
APC S20 Power conditioner -
What is the best matches for SDA SRS's for center channel?
Thanks,
engtazengtaz
It appears that the best match would be a similiar speaker(s) that are small enough to fit above or below your display. Here is a very nice example of what I personally would use if I could find a pair locally. http://www.polkaudio.com/forums/showthread.php?t=49616 REGARDS SNOWengtaz wrote:What is the best matches for SDA SRS's for center channel?
Thanks,
engtazWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
I just aquired a pair of SDA CRS's and need advice as to how to use them as a center channel.
I have been using a pair of CS400i's and have tried a CS-350 but they don't seem to match well with the main speakers
My main speakers are a bi-amped set of SDA-SRS's set about 15 feet apart, using Musical Concepts DH-500's. I play music only with 2 channels, but need a center for movies and TV. I plan to power the centers using a two channel amp DH-500, same as bi-amp amps
I am looking at these options:
1. Use both speakers for center using interconnect Cable, speakers side by side or stacked.
2. As above with no interconnect cable.
3. Rewire speakers to make them non SDA. Looing at the schematic it appears that the woofers and tweeters in each speaker could be paralled.
Not sure how they would sound.
4. use one speaker for center.
Thanks in advance for any help on this,
Bill -
The IC cable won't act as it does with stereo signals since only 1 signal is present, but having a signal pass through the dimensional mids will still help bass respnse. I would try it both ways and decide for yourself what fits your needs.
I would try option 1 first, then try option 3. Let us know what you find out.
Remember that option 1 uses 4 mids, while option 4 uses 1.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Bill
Hi Bill,
I am not sure whether the tweeters and mid-range drivers in your SRSs are identical to the CRSs, as they are in my setup described earlier, but I believe the switch to the CRSs will likely improve the timbre match from the CS400is.
The issue of using dual center channels is rather controversial, mainly because it is possible that such an arrangement will promote comb filtering distortion.
I personally believe that the horizontal arrangement of dual centers is going to create a situation that defeats precise center imaging and promoted comb filtering. I believe that stacked centers yield a focused center image that can provide a phantom image centered both horizontally and vertically on the display. I also believe it is less prone to comb filtering effects because all the members of the audience are virtually equidistant from both centers.
I think dual centers are most likely to be helpful in situations where there is a large sonic hole between the mains, as in the case of widely separated mains. If the mains are closely space, then I think the usefulness of dual centers is marginal.
For the reason mentioned by Dennis I do not use the Interconnect on my centers. (My appologies to Lasareath for missing his earlier question on this point.)
With regard to rewiring the CRS, Raife (DarqueKnight), who posted earlier, is an expert on this subject and has done this with great success. I don't have confidence in my soldering, etc., skills and have not attempted it. I believe the advantage is to permit the dimensional drivers to be active, whereas they will not be active when feed monoaural signals, with or without the Interconnect.
Before commiting to dual centers you should try listening to a single and dual arrangement and see which you prefer. I prefer dual stacked for my particular arrangement.
Good luck.
Larry -
My CRS woofers and tweeters are the same as my SDA-SRS's they are SL-2000's and MW-6503's..........Just need to know exactly what I should do make a mono speaker out of each. From the schematic it appears if I just take the SDA ground and connect to the speaker ground and not use the IC cable I would have Mono speakers. However I do notice a resistor and some of the caps are different between the SDA drivers and the mains. Should I change them or not. I plan to install Mills Resistors and Sonic caps soon. Thanks
Bill
