SDA 1.2TL'S A1 sda cable
warlocks1
warlocks1 Posts: 1,284
edited February 2007 in Vintage Speakers
I picked up the pair of 1.2TL's today. Picture will be up shortly, after I get someone over here to help me unload. The speakers came with the Polk A1 cable. I will be running it through a B&K common ground amp. Can I still use the cable or should I use the regular one that I have with my SDA's 2.3? Thanks, Jeff
  • DarqueKnight
    DarqueKnight Posts: 6,765
    If you are using a common ground amp, there is no need to use the AI-1 and thus introduce another component into the signal path.
    If you are curious, you might try hooking up both cables and comparing the sound with a variety of source material.
