SDA SRS2 tweeter and cable
hqdb
hqdb Posts: 13
edited February 2007 in Troubleshooting
I just bought my first SDA speakers yesterday for $200 and they need two new tweeters and the SDA cable. Can I replace my SL2000's (which have a red SRS stamp on the rear label) with any SL2000 from another speaker (say model 8 or 10 from ebay), or does it have to have the SRS stamp? Also, if I were to upgrade tweeters, is the SL2500 (from newer model 8's and 10's) or the SL3000 a better tweeter? These speakers were pretty inexpensive and I dont want to sink too much money into them and ruin a good deal. Next, how do I make a new SDA cable, as I understand the blade/pin version is not available for sale. I noticed a few threads about soldering ends on some speaker wire, but there is mention about common grounding and things which I am unfamiliar with...can someone help explain the home manufacture process. Thanks!
Garage System - The only room where I can "Turn IT UP"
HK Receiver/CD Changer
Polk SDA SRS2
Polk RTA 15TL
Post edited by hqdb on
  • Ricardo
    Ricardo Posts: 10,636
    Welcome and congrats on your purchase. You can (and should) get the new silk replacement tweeters from Polk customer service; just give them a call and mention you're a forum member. You'll get a discount plus free shipping.
    If your interconnect is the pin/blade, you can just use any decent speaker wire to connect the pins. You do need a common ground amp to run these speakers.
    Good luck!!
    SOPA
  • george daniel
    george daniel Posts: 12,096
    Also, for the pin/blade interconnect you can take the speaker wire--12-14 guage,insert into a male rca connector,remove the "collar" from it,and you will have a decent/secure homegrown cable.
  • hqdb
    hqdb Posts: 13
    How can I get one of these Polk Compendium books? I tried to send a message to DarqueKnight but because I am a new member I can not send private messgaes yet. It really looks like a great resource and exactly what Im looking for.
    But does anyone know if these mid-woofers , with all sorts of varied 65** numbers are interchangable? I was thinking of buying a pair of the smaller bookshelfs for parts but am not positive the drivers are exact models.
    Thanks for the help!
    Polk SDA SRS2
    Polk RTA 15TL
  • hqdb
    hqdb Posts: 13
    Thanks! How do I contact Darque Knoght? I tried sending a personal email but the system will not allow it since I am a brand new member. The compendium looks like a great resource.
    Also, does anyone know if the all the 6.5 inch midwoofrs are interchangeble? If I were to buy a small bookshelf set for parts, could the woofers be used in the larger SRS series?
    Thanks for all the help!
    Polk SDA SRS2
    Polk RTA 15TL
  • hqdb
    hqdb Posts: 13
    HT Rookie,,,this may be a stupid question, but whats a common ground amp? I am running a HK 120 WPC receiver to them now, but may buy an older Adcom, Onkyo, or Carver amp to power them using the HK pre-outs in the future. I have to wait and see what they sound like when all is fixed- I havent even fired them up yet.
    Polk SDA SRS2
    Polk RTA 15TL
  • SLOCOOKN
    SLOCOOKN Posts: 704
    Adcom GFA 555 mk2 Common ground...Carver TFM 55x common ground. If an amp is selectable to be bridged is is USUALLY common ground. Always check with the manufacturer .
    :eek: From the bottom it looks like a steep incline, From the top another down hill slope of mine.:mad: But I know the equilibrium's there!:cool: .."Faith No More" :D
    Sony cx985v (for now)
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    AudioQuest Crystal 2 spk wire
    Nordost RCA
    SDA 3.1 tl RD0 tweets
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
    VMPS Original Tall Boy (Mega Woofers soon)
  • Ricardo
    If you have a multimeter, just measure ohms between the negative binding posts (black speaker outputs); you should read 0 ohms (or very close to 0).
    Most amps are common ground, but there are a few that are not; if you use a non common ground amp, you might fry your speakers/amp/both.
    Not all MW drivers are the same, and some are not interchangeable; in this link you can find a list for your speakers:
    http://clubpolk.polkaudio.com/service/models/modelpartslist.php3?model=sda
    SOPA
