CS200 Center speaker with MW4801 driver
hvoges
hvoges Posts: 13
edited February 2007 in Troubleshooting
Hi, I have a CS200 Center Speaker that contains two MW4801 drivers. One of the MW4801 drivers is bad and Polk no longer carries this driver. I asked if they sold anything that replaces this driver, but they said they didn't. Are there any third party drivers that one could recommend for this application?
Post edited by hvoges on
  • Mike20878
    Mike20878 Posts: 5
    What do you mean Polk no longer carries it? I called a month or so ago and was told it was on back order. They took my information and said they would put me on a contact list when they were back in stock. This is ridiculous. I was getting ready to post a message to check on the status of this part.
  • dougr
    dougr Posts: 124
    post in the WTB forum... I have a CS250S with 2xMW4801 that is in need of a tweeter ... I've started down another route, and will likely have both MW4801s available within 2 wks.
    ______________________________________________
    RT16 x4, LS/fx x2, CS350 x1, HK247, B&K av5000, B&K avp-2030, pio bdp-51fd, InFocus X10 and a $13 sheet of doable :)
  • Mike20878
    Mike20878 Posts: 5
    I called customer service and learned that if I send in my damaged driver they can sell me the CS1 (the equivalent replacement for my CS275) at a substantial discount of $93.57 plus shipping & tax. I looked it up and it retails for $199.95. I may actually do that.
  • dougr
    dougr Posts: 124
    ... you do not own mains and surrounds with the Sl6501 tweeter and want an exact match. they say it is close enough, but many around here insist on the same tweeter model across the front soundstage. If you do not own RT7, RT16, etc, the newer route is probably the better option, as the older stuff is getting expensive to fix (hard to find).
  • Mike20878
    Mike20878 Posts: 5
    I'm not that picky. I have a variety of speakers right now. I forget what model left & right channel I have, but I can check when I get home. They're bookshelf models and are about 24 years old and working great. :)
  • Mike20878
    Mike20878 Posts: 5
    Got your PM but can't reply...silly rule.
    Anyway, I misunderstood your post. I thought you meant you were getting some you needed for yourself. Would the cost be about the $48 Polk was charging?
    Thanks.
