denon AVR-1706
    edited March 2007
    Easy on that volume dial hombre.You don't want to start a thread about
    blown tweeters do ya ? Enjoy your new stuff !:)
  • 98thumpin
    98thumpin Posts: 649
    edited March 2007
    how can i blow my tweeters if im only pushing 85 wpc and the speakers are rated at 275 watts max.
    John Tyler Birch
    home audio system:
    Denon avr-1907
    Sony dvd/cd changer 5 disc
    nakamichi BX-100 tape deck
    2 Polk Audio monitor 70's
    Velodyne DPS-12 subwoofer
    RCA TV
    NAK 600 tape deck
    Monster power line conditioning power center
  • McLoki
    McLoki Posts: 5,231
    edited March 2007
    From your friends at about.com
    Q. Will My High-Powered Amp Blow My Speakers
    From Apply Now,
    Your Guide to Stereos.
    A. Many people wonder if an amplifier can blow their speakers when delivering full power to the speakers. The short answer is "No." The long answer is "well, if your amplifier is high-quality, you are OK." With power-handling, a higher rating is like almost everything else: more is always better. A speaker might have a minimum requirement for power handling, based on its sensitivity and performance, but will most likely have a maximum allowable amount.
    A speaker with a 100 watt power handling rating can be safely operated when connected to a 500 watt amplifier. The speaker is not going to explode or anything like that. The truth is that high amplifier power almost never destroys a speaker. In most cases, it is a lack of amplifier power that causes damage. The key is to use your speakers with an amplifier that produces sufficient output to drive the speakers to realistic sound volumes without distortion, or "clipping."
    Clipping occurs when the amp is asked to deliver more current to a speaker than the amp is really capable of doing. When an amplifier clips, it literally cuts off (or ... clips) the tops and bottoms of the musical waveforms that its trying to reproduce. This phenomenon introduces a huge amount of distortion into the output signal, and it is that distortion that kills speakers. The maximum power-handling amount stated on a speaker basically assumes that the amplifier is going to "clip" or start to produce distortion at its maximum output. So, if you use a low-quality amplifier, it will start to run out of gas at its max output, and might do damage to your speakers.
    A high-quality amp usually produces ample power without clipping and thus it avoids the introduction of speaker-killing distortion.
    Edit - for a much more technical description. Look here.
  • TroyD
    TroyD Posts: 13,124
    edited March 2007
    Essentially, when you are blasting away...your receiver is going to start sending spikes of DC that will fry your tweeters.
    Enjoy.
    BDT
  • 98thumpin
    edited March 2007
    i didnt know that. so is it safer on my speakers to run them at high volume with more power.
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • Sherardp
    Sherardp Posts: 8,038
    edited March 2007
    With clean high current power, you wil be fine. As in using a Power Amp.
    Just curious, have you tried listening to your system minus the EQ? Have you tried using the EQ settings within your AVR thus far?
  • McLoki
    McLoki Posts: 5,231
    edited March 2007
    A more accurate way of saying it would be:
    "When listening to your speakers at high volume, it is safer to do so with a higher power amplifier than a lower power one."
  • cfrizz
    cfrizz Posts: 13,415
    edited March 2007
    Why hasn't anyone ever posted this before???? Well I will be from now on when the question comes up, since I have saved it to my hard drive.
    It's going to save a lot of time & typing!!!:D
    Thanks Michael.:)
  • 98thumpin
    edited March 2007
    The eq isnt hooked up its just for show, and i listen to my system in analouge mode. i dont like the way the preset eq's sound.
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • 98thumpin
    edited March 2007
    Ah i gotcha higher power means less chance of power spikes cause the amp isnt working as hard.
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • 98thumpin
    edited March 2007
    which means longer life for both.
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • 98thumpin
    edited March 2007
    Can anyone suggest a good quality amp that puts out 200 wpc rms cleanly for under 1000 if not suggest brands and ill look in the used market.
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • Deadof_knight
    Deadof_knight Posts: 980
    edited March 2007
    You can find an adcom 555 or a carver tfm-35 for around 250-350 all day everyday, Good bang for the buck in my opinion.
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
  • 98thumpin
    edited March 2007
    what kinda power do they make
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • 98thumpin
    edited March 2007
    Should i just amp my front left and front right at 200 wpc or should i bi amp the fronts, and amp the other channels with a 100-150 wpc amp, im going with monitor series bookselfs the m-40's as surround speakers.
    also can any one reccomend a center channels that while go good with these speakers. I had thought about a cs-2
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • Sherardp
    edited March 2007
    Sounds like you have a good plan, just try letting the power amp run everything, if you dont like the sound, you can go and try biamping. As for the center the CS-2 is a good choice. When connecting your power amp, try to use a good audio interconnects, blue jean, signalcable, audioquest,bettercables.com you get the idea. What amp are you considering?
  • 98thumpin
    edited March 2007
    Well id love to have a Nakamichi PA-7 or two of them eventually to power my monitor 70's. That would be good for me when i listen to music in 2 channel stereo mode. I just love the way those amps sounded. But for now i may go with adcom, or something equilevent 200 wpc. a good used amp and then eventually add another amp cause i want to bi amp my fronts. then when i get the rest of my speakers, run them with the reciever untill i can run them with a 5 channel or 7 channel amp. and maybe eventually bi amp them as well.
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • 98thumpin
    edited March 2007
    What is a good affordable cable to use is monster cable any good there cheap on e bay. but i want a good cable with out having to pay 50 bucks or more for them.
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • 98thumpin
    edited March 2007
    any good affrodable cables out there?
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
  • engtaz
    engtaz Posts: 7,671
    edited March 2007
    Bluejean cable and monoprice.com cables
    engtaz
  • 98thumpin
    edited March 2007
    ok ill give them a look
    John Tyler Birch
    home audio system:
    Denon avr-1907
    RCA TV
    NAK 600 tape deck
