RT3000 Sub problem - weird noise
dpowell
I have tried the following with no difference noted:
Unplugged the subwoofer RCA cable
switched it off in the back
Switched it to always on
Unplugged and plugged back in
Any thoughts on what might be causing this?
Thanks.
Post edited by dpowell on
Hello,
In all likelihood the problem is with the bass amplifier. It would be best to telephone us at 1-800-377-7655 and we can discuss removing the amplifier and sending it to us.
Regards, Ken -
Polk CS is top notch and Kens the man.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
Thanks, all in a day's work!
Polk CS Top Notch
I second that.
Ken just helped me out behind the scenes.
MLSI like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D -
Thanks Ken, will do.____________________________________________________________
