Lost metal jumper. Workaround?
Democritus
Democritus Posts: 2
edited June 2009 in Troubleshooting
I have a CS400 I bought years ago. During a move, The metal jumper plate between the two (-) binding posts was lost. Do I have to find another one to make it work or can I do something like string a piece of stripped speaker wire between the two posts as a workaround? Bi-amping is not feasible in my situation.
Thanks.
Post edited by Democritus on
  • McLoki
    McLoki Posts: 5,231
    edited February 2007
    speaker wire will work fine. (just strip the ends under the posts, not the entire length.) I am sure you could call Polk customer service and get some more if you wanted it to keep the factory look though.
    Many think that there are sonic benefits to removing the jumper (on purpose) and using some quality speaker wire in its place.
    Michael
  • ben62670
    ben62670 Posts: 15,969
    Take a piece of speaker wire and wrap it around both terminals. Some people acutually prefer this to the stock binding plates anyway.
    Welcome to the club
    Ben
    Ben
    F1nut Posts: 51,998
    Good quality speaker wire will work and sound better than the plates anyway, so do all your speakers that way.
  • edbert
    edbert Posts: 1,041
    Uh, yeah. What they said. If they are the same ones that are on the monitor line of speakers, you can have mine if you really want the originals. Just pm me your address. I think I have 6 total. Otherwise, just use speaker wire.
    I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius. :D
    Pioneer VSX-816
    Monitor 40's - fronts, bi-amped
    Monitor 30's - surrounds
    CS1 - center
    PSW10 - I'll let you guess
    Blue Jeans Cable - speaker cable
    Daewoo 27 incher - one step up from a console
    Sony Progressive scan DVD
    XBOX
    SOPA since 2008
    Here's my stuff.
  • Democritus
    Democritus Posts: 2
    Thanks, everyone! I didn't expect such a quick reply. I'll give it a shot...
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited June 2009
    Just bought a used CS400 to see how it will work as a center channel speaker to my SDA-SRS 2 mains. I noticed there are 2 sets of binding posts on the CS400 so I hooked up the speaker wires to the lower set of posts. First thing I noticed was that the tweeter wasn't working and one of the mid range speakers was louder than the other. Tried hooking the wires to the upper posts and the tweeter works fine but no mid range speakers. I'm going to guess that I need to make some jumper wires to go between the upper and lower posts. Like I said, got this thing used , as is. Thanks in advance!
  • ViperZ
    ViperZ Posts: 2,046
    edited June 2009
    Polkie2009 wrote: »
    Yep, just use a 12-AWG insulated wire to connect red to red and black to black. Then just use the banana plugs for the main speaker cables.
    On the other hand, I paid like $5 to Polk for a set of new jumpers for my CS400. lol.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • Polkie2009
    edited June 2009
    Thanks for the tip ViperZ, this is what happens when I don't get an owner's manual,lol. The banana plugs will go into the bottom speaker terminals,or does it really matter?
  • VSchneider
    VSchneider Posts: 443
    edited June 2009
    Connect to either set of terminals with the jumper in place; it doesn't make a difference, so use whichever ones are easier to reach with your placement.
  • Polkie2009
    edited June 2009
    Works like a champ,thanks guys!
  • Hillbilly61
    Hillbilly61 Posts: 702
    edited June 2009
    Hey Polkie,
    How does the CS400 sound with the SDAs? I was shopping for them heavily a couple of months back for my SDAs and settled for CS350s. 'couldn't be more happier! It matches so well that I've occasionally trotted up to the speaker early on to listen if they were working. That seamless. The center sound always sounds like it is ... coming from the center.
    Hillbilly
  • Polkie2009
    edited June 2009
    It seems to blend in well, I'm not sure if I have the CS400 or the CS400i. I know the tweeter is supposed to be different in the CS400i.
  • ViperZ
    ViperZ Posts: 2,046
    edited June 2009
    Polkie2009 wrote: »
    CS400 has black cones, CS400i has blue cones.
    B&W CDM1-SE fronts
    B&W CDM-CNT center
