RM6800 articulating brakets
VSchneider
Hi,
I am setting up an RM6800 for my father. The manual mentions that "articulating brackets, sold separately" can be used for wall mounting. What are these and how can I buy them? Are they specifically made for the RM series?
Thank you,
Val
Thank you,
Val
Post edited by VSchneider on
Polk has wall mounts available for their RM and DS speakers on their website and these specifically fit the speakers. I have included a link.
Or you can just buy any wall mounting brackets at any mega or audio store. I would just make a mental note of the mounts on the back of the speaker so that in the store you get something that matches up, and make sure you get brackets that works best for you and your application. (Some swivel, some rotate, etc.)
http://shop.polkaudio.com/webapp/wcs/stores/servlet/CategoryDisplay?langId=-1&storeId=12352&catalogId=13352&categoryId=51293&top=Y -
zingo wrote:Polk has wall mounts available for their RM and DS speakers on their website...
I see. I will pass this info to my dad. I think he was hoping to see something of the same style that comes with the RM's, but which can also tilt down in addition to side-to-side.
Thanks for the quick response. -
The rear threaded inserts are 1/4" #20. This is compatible with the Omnimount 10.0 series of mounts.-Eric
-Polk Audio
