Help: I-Sonic DVD Tray Won't Open
flashman2006
flashman2006 Posts: 1
edited January 2007 in Troubleshooting
I just got the I-Sonic system from polkaudio. So far I'm loving it, the sound is really impressive, better than my previous audio setup. But the DVD tray isn't working. Everytime I go to DVD/CD from the menu selection or press Eject, it goes to the DVD/CD screen but the tray doesn't open. All I see on the screen is "loading disc" and it stays like that. I have yet to put in a disk :( I tried disconnecting the system and leaving it like that for half and hour, but it still won't work.
I'll try leaving it unplugged overnight, but if that fails, anyone know what I can do?? Thank you.
Post edited by flashman2006 on
  • WilliamM2
    WilliamM2 Posts: 4,782
    edited January 2007
    Send it back and get another one.
  • Refefer
    Refefer Posts: 1,280
    edited January 2007
    Call Polk. They have top notch customer service and should be able to help you out.
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
    F1nut Posts: 50,841
    edited January 2007
    Hit it with a hammer.
  • Sherardp
    Sherardp Posts: 8,038
    edited January 2007
    As a former Marine we often referred to it as a BFH ( Big **** Hammer)
  • mrbigbluelight
    mrbigbluelight Posts: 9,896
    edited January 2007
    Sherardp wrote:
    As a former Marine
    There are no "former" Marines. ;)
    Have you tried excessive cursing and swearing. That usually works for me.
    ...... the contact Polk Customer Service has been the best idea so far.
    You'll get results.
    ...... in the meantime, though, try a few curse words.
