Help to remove Driver & Tweeter for Polk R150 speaker
t_babu
Hello this is my first post. I have Polk R150 speakers all of a sudden one of the speaker is not identifying by Avr 645. I called customer support and they asked me to remove Driver and Tweeter and send to service center.
I saw 4 screws for Driver and 2 screws for Tweeter. I am trying to figure out what tool exactly helps to remove both.
I really appreciate for your help.
Post edited by t_babu on
I had removed the driver for repair for Rti38 but can't remember what kind of screws they have. But if its hex screws then might wanna use allen wrech to take out the driver.
If its a regular screw then use Philips #2 or #1 screw driver.
I hope it helps.
Speakers=>Salk Soundscape 8, Soundscape Center,Surrounds-Dali Rubicon LCR, Lsi7
PreAmp, Amp => Marantz AV8801, ATI 6007 amp, Oppo HA-1 DAC
Source => Sonore MicroRendu, Oppo BDP-103, Mede8er 600XD, Dune HD Smart D1, Synology DS1813+(16TB)
Sub - JTR Captivator S2 (Dual 18")
Power - Furman IT-Ref20i on dedicated 30Amp circuit with Furutech GTX-R outlet
Screen=> JVC RS-45 projector Da-Lite HP 133" 2.35 -
Thank you malikarshad.malikarshad wrote:I had removed the driver for repair for Rti38 but can't remember what kind of screws they have. But if its hex screws then might wanna use allen wrech to take out the driver.
I hope it helps.
