Popping sound during system turn off
Lsi9
Lsi9 Posts: 616
edited January 2007 in Troubleshooting
Hey guys
I have my preamp triggering my Monster HTS2600 when I turn it off I notice a pop that emits from the drivers, is this dangerous? and is it avoidable somehow? Thanks
Audio Physic Scorpio II
Pathos Logos
MIT Shotgun S3
Bada HD-22 CDP
Post edited by Lsi9 on
  • Lsi9
    Lsi9 Posts: 616
    edited January 2007
    Ive tested it a bit and its my sub that is producing the sound, I use an outboard sub amp, I guess I'll try to turn it off before I shut the rest of the system off.
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
  • Ricardo
    Ricardo Posts: 10,636
    edited January 2007
    Might be normal; make sure you turn off the amp first, then once capacitors have discharged, turn the pre off. For turning on, first the pre, wait 30 seconds, then the amp.
    SOPA
  • goingganzo
    goingganzo Posts: 2,793
    edited January 2007
    if your amps are direct coupled you will hear a pop when the caps discharge mine dues it the olny way past it is to leave the amp on or turn it off befor the pre so it will drain the caps slowley
  • george daniel
    george daniel Posts: 12,096
    edited January 2007
    Adcom was notorius for that,,try turning your amp OFF first .
  • GUNTHER
    GUNTHER Posts: 22
    edited January 2007
    Have had this issue with my Adcom Amps forever when in Mono. Does not seem to have any effect on the speakers themselves. I never have gotten used to it though
  • jakelm
    jakelm Posts: 4,081
    edited January 2007
    I never turn my amps off. I believe keeping them on , keeps them warm so moister does not build up. My Hafler has a similar problem, but its been on for the past 2 years, never moved, never turned off.
    I guess if it was a huge amp , I would turn it off to conserve electricity. But my Hafler and Pioneer amps remain always on.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • McLoki
    McLoki Posts: 5,231
    edited January 2007
    My amp sends a pop to all the speakers when it is turned off. I checked it with an SPL meter and the pop was below 1 watt output. (based on the SPL - don't remember it now)
    It does sound bad, but has never hurt anything. Don't worry about it. (It never made any difference if I shut off my amp first, last or middle - it always send the pop to the speakers)
    Michael
  • Lsi9
    Lsi9 Posts: 616
    edited January 2007
    Thanks for the responses, yea its been doing it for awhile I just got a little more worried once I added the 826v's to the system but now I know its only my outboard sub amp doing it.
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
  • dagame27
    dagame27 Posts: 599
    edited January 2007
    my system does the same thing. I guess it is something with the Adcoms. It never has hurt anything though, and I have gotten use to it.
    ChrisIntegrated Amp: Cary SI-300D Processor: Marantz SR7012 Streaming: Bluesound Node 2I 4K Bluray: Panasonic UB820Mains: Von Schweikert VR2Center: Von Schweikert LCR15 Subs: 2 SVS Sb13 Ultra (HT Only) Analysis Plus Cables
  • AndyGwis
    AndyGwis Posts: 3,655
    edited January 2007
    I noticed that with my Carver M-1.0t. Just need to turn the amp off first and wait for discharge, as others have mentioned.
    One other thing is I'm getting a hum out of the speakers. With music off and just the pre and amp on, there is a constant hum that gets louder when the volume is turned off.
    Might need some wire management and/or deox the contacts.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • AndyGwis
    edited January 2007
    Okay, seems I have a ground loop issue from doing a few searches.
    good luck with your popping sound, I've got cheater plugs to buy.
  • avguytx
    avguytx Posts: 1,628
    edited January 2007
    Andy...mine does it too. There's supposed to be a fix for it but I need to do a little more research on it and see what it entails.
    Man, Dream Theater sure sounds good on the Carver/Polk setup! Sorry...had to say that since I was jammin' on that...lol.
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
