Replace SL2000 with RD0194-1
swloritz
swloritz Posts: 4
edited January 2007 in Troubleshooting
I currently have an older set of polk speakers with the SL2000 tweeter in them. One of the tweeters is worn out and in need of replacement. I read that the RD0194-1 is basicly the same tweeter as the sl2000 but better. If i want to replace my sl2000 tweeter with this one will it line up correctly though or will i need to make some modifications?
Post edited by swloritz on
  • dorokusai
    dorokusai Posts: 25,577
    edited January 2007
    It's a drop in replacement for the SL2000, nothing needed but a screwdriver.
  • swloritz
    swloritz Posts: 4
    edited January 2007
    nevermind... answered my own question :)
  • danger boy
    danger boy Posts: 15,722
    edited January 2007
    OR a Torx wrench ;)
    PolkFest 2012, who's going>?
    F1nut Posts: 50,841
    edited January 2007
    You'll want to replace all the tweeters for a sonic match as the new ones do sound different.
  • BaggedLancer
    BaggedLancer Posts: 6,371
    edited January 2007
    i plan to do this soon to all 6 of my monitors. Is there a direct order form for them from polk or do I need to call?
  • BaggedLancer
    edited January 2007
    anonymouse wrote:
    Call or PM Ken Swauger. I did the latter.
    Done. Thanks. Hopefully they aren't too pricey so I can do all 6 at once :D
    F1nut Posts: 50,841
    edited January 2007
    Call....ALWAYS call.
  • ESavinon
    ESavinon Posts: 3,066
    edited January 2007
    Don't forget to mention that you're a polk club member for a discount and free shipping.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
