Help!
Eric_Draven
Eric_Draven Posts: 7
edited December 2006 in Troubleshooting
Ok.. I'm a music junkie. I have 2 huge SONY speakers, Center speaker and rear speakers, all connected to a Pioneer VSX-D606S which is connected to my PC. everything worked X-cellent until this morning when my reciever simply didn't turn on! It makes the usual clicking noises that it does when it normally turns on, but now except for the noises- NOTHING. It simply won't turn on. I've checked ALL the wiring, took the wall plug out, put it back in- NOTHING!
Please help! I NEED MUSIC! :(
Post edited by Eric_Draven on
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    Welcome to the Forum Eric...
    The "clicking" you described sounds like it is attempting to turn on. Is there anything that lights up on the front display? Such as "protect"?
  • Eric_Draven
    Thanks ( My names not really Eric_Draven I'm just a Crow fan! (: )
    Nope... no lights at all.
  • zombie boy 2000
    Okay Mystery Guy:D ...
    at what levels do you usually listen to your music and what are the model numbers of your two front speakers?
  • Eric_Draven
    I don't listen to loud music.. just some background tunes while I work on the PC or have a chick in the room. The front speakers are OLD. SS-630.
  • joeparaski
    joeparaski Posts: 1,865
    A "chick" in the room...haven't heard that in a while:D
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
  • zombie boy 2000
    It seems those are 8 ohm speaks, so I don't think you overloaded your receiver. Have you checked to make sure all of your connections are secure? Mainly, the speaker wire -- with no conductors touching each other or overly exposed.
  • Eric_Draven
    Yep.. I checked if all the connections are connected and everything seems to be OK. But for some wierd reason it clicks and shuts off.
    F1nut Posts: 50,841
    Check the internal fuses, but I suspect you'll need to have the unit serviced by a pro.
  • Eric_Draven
    Yep.. I'll guess I'll just give it to the repair shop.. It's funny.. just this week my Sennhieser stopped working.. now this...
    Thanks for the replys and help everybody!
  • zombie boy 2000
    Sorry couldn't be of more help... let us know how it all turns out.
  • Eric_Draven
    Well, I opened the reciever. So much stuff in there and suddenly I saw a burned out fuse... the thing is so small! I can't believe it managed to screw up such a big machine.
    Thanks alot to:
    zombie boy 2000 and F1nut.
    I HAVE MUSIC!!! :)
  • zombie boy 2000
    Congrats! Can't take any credit though, as it was F1 who immediately nailed it:)
    Again, Welcome to the Forum and be sure to stick around.
    tonyb Posts: 33,028
    Congrats Mr. Crow but the problem may still exist.Running the kind of gear you have should not blow a fuse.Do you have stuff or other gear stacked on top of it?Make shure your speaker wires are not touching each other at the connections.Glad you have music again,does help with the chicks.:)
  • Eric_Draven
    Nope.. nothing stacked on it.. but I sure do have a JUNGLE of cable and wires at the back. I'll clean it up though. Thanks guys! :)
  • Sansui
    Sansui Posts: 372
    The Crow #1 is one of my favorite movies! I thought #3 was better than #2.
    Oh yeah, this is the place to ask for help. The people here have helped my learn a lot so far. Answers come quickly too!
    Be gentle, I'm new to all this...
    The mind blowing speed of the BRAIN TRAIN...
