hooking up subwoofer to reciever - cable problem ?
pmontagne
pmontagne Posts: 1
edited December 2006 in Troubleshooting
I purchased an Onkyo TX-SR504(B) AV Receiver and a Polkaudio RM6750 audio system from Circuit City. Hooking up the system and ran into a snag; The reciever has a pre out for the sub woofer which is a single connection and the subwoofer has a line in which is a double connection. What kind of cable do I need for this hook up?
Thanks for any help,
Pat:confused:
Post edited by pmontagne on
  • ben62670
    ben62670 Posts: 15,969
    Read the directions. It will tell you which jack you need for mono ie. left or right.
    Ben
  • louthewiz
    louthewiz Posts: 581
    Use a Y connector to feed both inputs on the sub so it will give you a 3 db boost.
    My gear,
    Acer PH530 720P PJ
    100 inch Da-Lite Video Spectra screen
    Yamaha HTR 5790
    Toshiba HD-A3
    Denon 1600 dvd player with sdi out,
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    1 Audiosource amp300 150 wpc Fronts
    1 Audiosource ampone bridged 200 watts powering center
    1 Onkyo M-282 105 wpc amplifier sides
    polk cs400 center
    polk RT400 mains
    Polk mkII back surrounds,
    Polk FX300fxi dipole surrounds
    Velodyne DPS-10 sub
    Klipsch KSW-10 sub.:cool:
