Yahama RX100 power problem
mikeh51a
My old, approximately 20 years, receiver has stopped working. Worked OK one night, tried to turn it on the next and nothing happens. The power switch makes a clicking sound when pushed like it's working but nothing lights up. Power is getting to the unit, fuses test OK. Any ideas? Where can I find a service manual? Or is it worth trying to fix?
Post edited by mikeh51a on
Hello,
It's always difficult to know where to begin when trying to figure out what is wrong with a piece of electronics. Is the front display coming on? In other words does it appear that everything's coming on, but there's no sound?
Regards, Ken -
Open it up and check the power fuse next to where the power cable comes into the amp, and make sure it's unplugged you'd be surprised it can be an easy fix..........My gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool:
