Adcom GFA-585 problems
    heiney9 Posts: 25,409
    edited December 2006
    Also for kicks after you put everything back together it would be a good idea to power up and check the DC offset at the speaker terminals with a volt meter (mV) and let it idle for a good 60-90 minutes and check again. That way you won't fry any VC's on any speakers even if they are cheap JVC's. One of the easiest things to check for is large amounts of DC leaking to the speakers.
    Also those boards are not available from Adcom or anywhere else for that matter. So cleaning them up really well and inspecting for any trace cracks is very important. I've read of people taking blank boards and making their own traces, but that takes a $hitload of patience and know how. So do your best to really clean them up well with a process that doesn't damage the boards.
  • ben62670
    ben62670 Posts: 15,969
    You seem almost as nervous as I am.
    Ben
    I just know what a nice amp that is and the fact that it's a limited run and some parts are hard to come by. Just wanted to pass on some info.........:D . There probably isn't anything that can't be fixed some way, but it's much easier and much more cost effective to do it right from the beginning than it is to try and fix a bunch of bad blunders.
    If this were a typical inexpensive straight forward design where parts were easily interchangeable and a dime a dozen I'd say go after it with reckless abandon..............but that's not the case here. So caution is the order of the day.
  • ben62670
    Yes sir I fully absolutely 110% appreciate what you are saying. This amp is #1096 out of a run of 2000 or 3000. I forget. The person I purchased this from on ebay said they would give me a full rebate minus the shipping. I didn't want to loose the $100+ round trip on shipping, and risk the amp being damaged even more. So I kept it.
    Ben
  • unc2701
    unc2701 Posts: 3,587
    Well, I feel better knowing that my old one isn't out there **** you over... I had #1580 :)
    (In case you're wondering, I still have pics on my computer from where I ebay'd it).
    Backburner:Krell KAV-300i
    It's funny you should say that. My brother has an Adcom GCA-510 which is in my possesion currently and the caps are leaking (seems they are anyways light sticky residue around the 4 caps) and some prior owner has been inside and lost screws and had the output board out because there are large burrs on the brass nuts that attach the wires to the speaker terminals. Apparently he didn't know what he was doing. I think the amp sounds off and my bro is going to sell it and disclose that it might have some issues. I'm still looking for one of these so I am going to copy down the serial number so I don't buy it later down the line.
    Someone got into this unit and had no clue what they were doing adn while it might sound fine to most I've had it hooked up several times and it just seems to be a bit off, nothing drastic but it just doesn't sound quite right. If I were to repair it I'd have to buy it from my bro and I'm not interested in paying for it and then sending it for repair.
  • ben62670
    "Someone got into this unit and had no clue what they were doing "
    It wasn't me.
    I'm about 20 minutes away from firing her up. Not setting her on fire! Are the caps Elna caps? I wouldn't hesitate at all on a preamp. There isn't much juice running through it to hurt much. But... It isn't yours either. Is it wrong to pray for an amp?
    fingers crossed and praying Ben
    Ben
    It wasn't me.
    Not Elna caps and the GCA-510 is Adcom's version of an integrated. 50 watts per channel it's a bit odd because the pre-amp section is line stage passive. It's essentially a Gfa 535 with the SLC 505 passive controller in one unit. It's slick but it's not mine and I'm not messing with it.
    Good luck and be sure to report back
    The GCA-510 has over 27,000 uF of filter capacitance so it could give you a good zap if you aren't careful :D .
  • ben62670
    Cold start on momentarily, back off. No smoke. On 20 seconds 30mv on the bias. No smoke.
    Ben
  • ben62670
    18,000 uf at 81.7 volts x 4. 84,000uf at 81.7 volts = grown man with tears in his eyes. Time for another power cycle.
    Ben
  • ben62670
    Mental note. Large metal output transistors contain some form of alternating current. Use caution when reaching for bias testing legs on output circuit.
    Ben
  • unc2701
    What's that noise? It's your brass balls knocking together.
    Be careful there, dude.
  • ben62670
    blue balls :D
    heres what has been going on
    http://www.diyaudio.com/forums/showthread.php?s=&threadid=92926&perpage=10&pagenumber=1
    I was told to look for open 10ohm resistors, and I found all 4 were open!
    Input ground was running through the preamp. No way to get proper bias ajustment, or DC offset
    Ben
  • Systems
    Systems Posts: 14,873
    Nice,making fun of our attempts to help you (post#14at diyaudio):rolleyes:
    Testing
    Testing
    Testing
  • doggie750
    doggie750 Posts: 1,160
    Hello Ben,
    Just wanna say that you are in good hands, ANATECH from DIY helped me with my Carver once. He's a PRO. You are in my thoughts and prayers.....I've been in your shoes before so just have faith with the DIY gurus.....
    Just a thought: You might wanna replace the coil/ power supply due to the overheating issue.
    Merry Christmas and a Prosperous New Year:D
    Godspeed,
    D0661E
    AVR:Pioneer Elite SC-07
    Surrounds: RTis
    2channel:Rti100 (carver driven
    Sub:SVS PB12-Plus/2
    Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
    Wsrn:Hitachi ultra vision LCD60, 32XBR400
    PowerConditioner: MonsterC HTS5100
    PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
    MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
    Odyclub; Xsimulator; Sony; Zune; Canon
  • ben62670
    I should have been more specific. I was poking fun at me for playing with live electricity.
    "Replaced the caps, and some of them exploded."
    "I will hook it up to my SDA2's because they can handle the most power out of my speaker collection. I'm just kidding, and I only said that because I know you guys can't slap, and sterilize me so I don't reproduce via the INTERNET."
    "Cold start on momentarily, back off. No smoke. On 20 seconds 30mv on the bias. No smoke."
    "Mental note. Large metal output transistors contain some form of alternating current. Use caution when reaching for bias testing legs on output circuit."
    I caught a little juice inspired me on that last quote :eek:
    Actually if I were to give out a prize for best guess on what the problem was it would be a tie for leaking caps, and ground loop issue via the input boards, due to four 1/4 watt 10 input resistors.
    Many thanks to all who posted. Without the posts here I would have never gotten as far as I have come, and I am still trucking along :D
    Ben
    Glad we could get you pointed in the right direction and it sounds like things are working out for you so far. Anatech knows his stuff :cool: .
  • Systems
    OK I forgive you.:D
    Its great you found someone(Anatech) that has expierience with that particular amp.
    Be sure to practice safe electronics.
    Testing
    Testing
    Testing
  • ben62670
    Done and Done
    Seems to work perfect!
    Thanks for all your help!
    Ben
  • Systems
    Great:)
    Testing
    Testing
    Testing
