Opening M3 case
jmichi
jmichi Posts: 4
edited December 2006 in Troubleshooting
Hi,
I need to replace an M3 tweeters. How do I open the speaker case ?
Post edited by jmichi on
  • SLOCOOKN
    SLOCOOKN Posts: 704
    i HAD A PAIR OF M3'S AND DROPED ONE AND THE FACE SEPERATED FROM THE BACK. THEY STILL SOUND OK. MABE NOT THE ANSWER YOU WERE LOOKING FOR IT WAS JUST MY EXPERIENCE. :)
    :eek: From the bottom it looks like a steep incline, From the top another down hill slope of mine.:mad: But I know the equilibrium's there!:cool: .."Faith No More" :D
    Sony cx985v (for now)
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    AudioQuest Crystal 2 spk wire
    Nordost RCA
    SDA 3.1 tl RD0 tweets
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
    VMPS Original Tall Boy (Mega Woofers soon)
  • [Deleted User]
    [Deleted User] Posts: 7,658
    Hello,
    I try and encourage any M3 owner to send the speaker to us for service. The enclosure can be easily broken if you are not very careful. Even our longtime dealers will send the speakers to us rather than risk the cabinet (which we no longer have). Is this something you would like to consider?
    Regards, Ken
  • jmichi
    jmichi Posts: 4
    Kenneth,
    Could you at least give me an idea on what is process to open it ? I did remove the screws and I can see the tweeter and bass would come off together as a whole, but somethings holds the face into the box.
  • xoaphexox
    xoaphexox Posts: 246
    Kenneth, I have a set of 9a's that I am trying to get inside. Two of the 4" drivers ceased working and I want to check the connections and wiring/crossover. The grey cement that holds the speakers in place along with the screws seems to be preventing this. I did not want to damage the speakers getting inside.
    Can you offer any advice? Thanks!
    Burson HA-160D > Adcom GFA-5802 > Polk SDA-SRS 1.2tl w/ Mye Sound Spikes, Mills/Sonicap XO, Larry's Rings, Dynamat Extreme, Cardas CCGR Binding Posts and Jumpers, Custom 10ga interconnect, Custom Gaskets, RDO-198
  • [Deleted User]
    Hello,
    I believe Helen, in Customer Service, has a set of instructions on opening the M3 that she can send. Just send an email to hyarbor@polkaudio.com and ask for M3 opening instructions.
    Regards, Ken
  • [Deleted User]
    Hello,
    I'm afraid my experience is very limited on the older 9 series speakers. In general terms after you remove the screws you can use a putty knife to loosen up the tweeter and driver. You would want to place a couple layers of heavy paper to prevent damage to the cabinet surface.
    Regards, Ken
  • jmichi
    jmichi Posts: 4
    Kenneth,
    I just sent Helen an email. I tried using a putting knife but the case doesn't open. It looks like there is something else other than the screws holding the case together. I will wait for her reply.
    Jorge
