Problems with my System
Amplified
Amplified Posts: 7
edited November 2006 in Troubleshooting
Hello,
Just some background information. I bought this system from Tweeter, it is my first system I have ever purchased so I am unfamiliar with most technical terms relating to speaker systems in general.
The Products I bought are as follows:
Sony Stereo Audio Receiver - STRDE197 http://www.abtelectronics.com/product/15452.html
Polk Audio Speakers x 2- T20e
http://www.polkaudio.com/homeaudio/products/t20e/
10-inch Powered Subwoofer - PSW10
http://www.polkaudio.com/homeaudio/products/psw10/
After I bought the above products I wired them correctly in my basement. Within 2 hours of use the speakers started to distort and the bass on the speakers was sounding like an open drum. Granted I was playing them loud, because they are intended to be used for parties. I was playing them at 85% of max volume allowed by the amplifier. Needless to say, I returned the speakers and exchanged them for new ones.
I arrived at home with the second pair of speakers and wired them up correctly. I play music through a laptop that connects to the amplifier. I turned the volume up to 40/72 on the amplifier which is a little over half volume (not loud), and a puff of smoke emerged from the right speaker's tweeter. The speakers were blown again...within 5 seconds of turning on the music. I figured it might have been a power surge or something. We connected the amp to a power strip that connects to an outlet in the basement. The outlet in the basement is high powered im guessing because we plug the hot water heater into the same outlet...we leave the hot water heater unplugged when we use the stereo.
I returned to tweeter with the amp and the 2 speakers and they were all broken. I received a new amp and 2 speakers and set them up again. They worked fine for 3 hours during a party playing at 65/72 volume and now they are broken again a week later after no use.
My question is what steps should I take to rectify this problem. I figured speakers could be played at near or max volume... why would they have that setting on the amp if it was harmful to the speakers? It doesn't make sense to allow the sound to reach a level that would damage the speakers...Any suggestions would be appreciated !
Thanks in advance.
Post edited by Amplified on
  • wallstreet
    wallstreet Posts: 1,405
    I never go past 12:00 on my amp. 1:00 is tops for any receiver. If it's not loud enough at that point, your receiver is underpowered (which yours is).
  • MillerLiteScott
    MillerLiteScott Posts: 2,561
    How high does the speedometer on your car go up to?
    Do you drive it that fast for hours at a time?
    Just saying.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • AndyGwis
    AndyGwis Posts: 3,655
    I have the same speakers (the T20ebs), and, albeit in a smaller room, I could get those things up very loud with no distortion or fading on my B&K St-202.
    Unless you've hosting a rave in a huge area, the speakers should be the problem. I'm not sure if the receiver is hearty enough for insane listening levels, but I'd guess it would run out of steam before the speakers blew up. Also, I would think your ears would give up somewhere inbetween the receiver and the speakers.
    Sounds like you should get something that's a little better suited for your particular application. Maybe some Cerwin Vegas or white van speakers. Stuff that can get crankin really loud, to the point that you can't tell how good it sounds anyways.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • Drumingman
    Drumingman Posts: 348
    :D Gee, I hate to tell you this but the Sony is a piece of crap.
    First it's power is rated from 40 to 20 K @ 100 watts per channel.
    This is the first indication that they REALLY Scrimped on the amp.
    Never buy a reciever with poor specs like that and expect it not to blow up your new speakers. If you buy a higher quality unit like a Harman Kardon or a Denon, somethng in that class, you will not be blowing speakers up.
  • Amplified
    Amplified Posts: 7
    Thanks for the responses. I'm sure if I drove my car at top speed I would not have a problem; got to love BMW engineering :D
    I'm guessing the optimal solution is to buy a better receiver.
  • MSALLA
    MSALLA Posts: 1,602
    You say you plug this into the same outlet as your hot water heater. Check the outlet power. That sony is not all that great. I don't know what your budget is like but if you can, return it and upgade. Your only using it for 2 channel, so you can get a fair receiver for another 100 to 150 (not great but better.) I'm surprised it smoked like that. Have you ever had any problems with your hot water heater.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
  • Amplified
    Amplified Posts: 7
    No we haven't the hot water heater has always run fine. It is probably a pretty high voltage line but I thought that didn't matter since the receiver only draws the power it needs? I'm not to familiar with electrical wiring so I could be wrong. All I know is we have ruined 3 sets of speakers and I need to figure out why before I walk into Tweeter again haha :cool:
  • MSALLA
    MSALLA Posts: 1,602
    Ditto!!! my 530i loves to scream all day.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    Harmony 880
  • Amplified
    Amplified Posts: 7
    325i here, I'm from Media PA noticed you were from Drexel hehe.
  • ledhed
    ledhed Posts: 1,088
    A rule of thumb is to NEVER turn the volume past 12 o'clock. Also, if you are just doing 2 channel, you could get a Harmon Kardon or Denon for about 200-300 that might do better
    God shows his love for us in that while we were still sinners, Christ died for us. - Romans 5:8
  • cfrizz
    cfrizz Posts: 13,415
    He likes to blast his speakers, so he is always going to be burning out the speakers & the receivers, since receivers really aren't designed to play at extreme levels for long periods of time.
    What a waste of good equipment.
  • Amplified
    Amplified Posts: 7
    Well I dont want to waste equipment thats why Im posting on this board in an attempt to find a solution.
    With a budget of 800-1000$ what can I get that wont break? I intend to play the music loud, not incredibly loud for a 3-4 hour period once to twice a month.
  • tommyboy
    tommyboy Posts: 1,414
    so you spent all your money on your bmw?
    AVR: H/K AVR240
    Fronts: Monitor 50s
    Center: CSI3
    surrounds: R15s
    Sub:Velodyne DPS10
    Dvd/Cd: Samsung HD upconverter (for now)
    TV: 50" Sammy Plasma
    game hardware: 360 and gcn.
    Gamertag: kovster27
  • Amplified
    Amplified Posts: 7
    Sadly yes haha. I just don't want to pay more than 1000$ dollars for a stereo; I don't value it any higher than that.
  • joeparaski
    joeparaski Posts: 1,865
    You need to get PA suff for your parties, not home stereo equipment. Check the DJ equipment rental places, they may sell you some second hand stuff that will suit your requirements and not blow up.
    Joe
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
  • MSALLA
    MSALLA Posts: 1,602
    If your just talking for house parties, you could get away with some monitor 60's and a used higher end receiver. I'm willing to bet whats loud to you is not whats loud to most members on here. Are you playing the music so loud the cops are coming?
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    Harmony 880
  • tommyboy
    I can't believe I'm recomending this but:o
    http://www.circuitcity.com/ssm/MTX-PA-DJ-Speaker-TP112/sem/rpsm/oid/75522/catOid/-12950/rpem/ccd/productDetail.do
    and get a cheap stereo reciever like the onkyo 8011, or 8511. From my experience, if you just want something loud, cheap, with no regards to sound quality(you only use it a couple times a year so...) this is the way to go...
    tommyboy
    AVR: H/K AVR240
    Fronts: Monitor 50s
    Center: CSI3
    surrounds: R15s
    Sub:Velodyne DPS10
    Gamertag: kovster27
  • Jim Shearer
    Jim Shearer Posts: 369
    Amplified wrote:
    Hello,
    Thanks in advance.
    OK, let's put it in car terms: that Sony reciever is the equivalent of a Yugo; the speakers are on par w/ a Ford or Chevy, while the sub is on the order of a Yaris. All will work within their limits, but the limits are modest. Would you expect a Yugo to keep up w/ your BMW? Then don't expect that reciever to perform like a couple of 600w Krell monoblocks! That you blew the tweeter in mear moments says you are driving the reciever into clipping, and that will destroy almost ANY speaker, no matter how much power it is rate to accept. It might be possible to use that small an amp if you have VERY efficient speakers--maybe Klipschorns (rather large and not cheap.) :eek:
    And as for the bass: if you want to shake the room, then you probably better plan on spending at least $1K on a sub, or perhaps a couple of subs.
    What you have presented is a very demanding application, which will require serious money. :(
    Cheers, Jim
    A day without music is like a day without food.
  • MSALLA
    MSALLA Posts: 1,602
    tommyboy
    You know what, this is right up your alley.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    Harmony 880
  • AndyGwis
    Those are pretty close to my idea of getting some Cerwin Vegas.
    Please get them!!!
    And, get some type of cheap power amp to play them at high levels. What's cheap with power over quality, maybe a Crown, Crest, or Gemsound amp off ebay? Hell, plug the source right into the amp if it has gain/volume control and go for it.
    Then, with whatever budget you have left, buy some glow sticks for your guests and rock the effin' paint off the walls!
  • Amplified
    Amplified Posts: 7
    Thanks for all the responses guys, its much appreciated.
    I think I'm going to trade in all my old stuff and just get a refund...
    I decided to give these a shot for speakers..
    http://cgi.ebay.com/Cerwin-Vega-VE-12-Tower-Speaker-New_W0QQitemZ9715843084QQihZ008QQcategoryZ71569QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
    Going to get 4 of them and place them around the room. Not going to get a subwoofer, since the 4 speakers will probably pump out sufficient bass.
    As for an amp going to go with..
    http://cgi.ebay.com/NEW-TECHNICAL-PRO-3000w-STEREO-AMPLIFIER-DJ-POWER-AMP_W0QQitemZ270057355100QQihZ017QQcategoryZ14983QQrdZ1QQcmdZViewItem
    Hopefully this works haha, I'm tired of breaking equipment :mad:
  • danger boy
    danger boy Posts: 15,722
    Joe
    I agree with Joe.. you need these or even bigger ones..
    http://cgi.ebay.com/2-JBL-JRX115-15-2-WAY-DJ-PRO-AUDIO-PA-SPEAKERS-JRX-115_W0QQitemZ270058140814QQihZ017QQcategoryZ47094QQrdZ1QQcmdZViewItem
    No matter what home audio speakers you buy.. you're going to toast them within minutes.. each and every time. Replacing your receiver is a great idea.. but with the party volume levels you like to listen to a few times a month.. save yourself the headache and get some pro audio speakers. they are incredibly rugged, and are often times used in dance clubs. that's the kind of speaker you need. get a big beefy amp and those pro speakers. as ugly as they are. that's what i would do.
    PolkFest 2012, who's going>?
