PSW10 Subwoofer suddenly dies!
MartyParty
Help - I have a PSW10 which is two months old. I just moved it to a new location in the room. I plugged in the mains power cord, then as I was plugging in the input cable (AV receiver switched off), the sub started humming, then there was a single clicking sound, then nothing. The LED is no longer on at all.
I unplugged the unit and allowed it to stand for an hour. Then I plugged in mains power again and it's still dead.
Any ideas?
MartyParty.....:eek:
Any ideas?
Post edited by MartyParty on
It may be as simple as blown fuse.If there is a fuse holder that is accessable on the back panel unplug the unit and check it.Testing
Testing
Testing -
Thanks GV#27 - Sadly the unit doesn't have any exposed fuseholders (bad design! - unlike the equipment of old).
I took the unit back to FutureShop today and they told me to contact Polk directly (talk about not standing by the products they sell). They have a 30 day return policy after that tough luck you are on your own (unless you buy their extended "profit" warranty).
Anyways I'll call Polk tomorrow to see if I can get it repaired in Calgary.
