Wall Paint Advice...
VR3
What brand makes a good paint for walls?
Also, what is the best type..
I dont want shiney walls, but I want something that can be cleaned...
Would like to keep it anywhere between 15-20 a gallon...
Post edited by VR3 on
You do really get what you pay for with paint. Pay less= more coats. Go with a satin finish as it cleans well, but doesn't reflect too much shine. Paints use flat/satin/semi-gloss/gloss ranges of sheen. You can get good results from Behr paints from Home Depot in your price range. Sherwin Williams is really a top choice for quality paints, but you will pay for the quality. >$30 gallon
Hint: If you want to go dark over a white wall, primer with a darker grey first to save on your topcoats.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Im going dark over dark...
Should I do anything to prep that?
I want this to turn out pretty good...
Havnt decided on anything yet...
But Im just redoing everything pretty much- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
You should be okay going dark over dark, unless your current paint is gloss, with too much slickness. Then I would prime to insure the new paint takes.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Current paint is flat enterprise paint from Lowes...
Its kind of a medium grey color...
Im thinking about doing two walls black (directly behind TV and seating wall) and the side walls a color my step Mom used in my room at my Dad's house which I havnt seen in forever, I need to ask them what its called... lol
I want the black walls to make things dissapear a lil better when watching movies...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
American Tradition from Lowe's seems to be solid. I've used it several times.
Baer from HD is rock solid as well. Painted many many houses with it. Go with an Eggshell sheen when painting interior walls. A satin will reflect too much, IMO.
Good luck with the project!Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
SVS PB12-NSD/2 - sub
Denon 3805
Rotel RB-985 5-Channel Amplifier -
Or go to a real paint store and ask for some advice...
Dennis Gardner wrote:Hint: If you want to go dark over a white wall, primer with a darker grey first to save on your topcoats.Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
Behr Paint for interior IMHO.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
I've used literally hundreds of gallons of Benjamin Moore's eggshell finish paint with great results.
It holds up better than flat paint to cleaning but doesn't "shine" like semi gloss paint. It's great for kitchens, kids rooms and high traffic areas. Although hardy enough for bathroom use, a semi gloss is still the best for that application. -
+1 for BM. If you want really good stuff, there it is.
A painters vote for California brand paints if they are in your area. Big on the East coast and is the only brand we currently use. Their "Super Scrub" ceramic paint is excellent. Totally washable and holds up well against "burnishing", a problem that occurs with dark colors.
FYI- American Tradition from Lowes is a solid economical choice.
And ditto Dennis' comment on "you get what you pay for":)The Flea rig
Hitachi 50VG825 LCD
Rotel RSP 1066 (pre) -flea market
B&K St-202 (mains)-flea market
Carver M 200t (x2) (center and surrounds)-flea market
Blu-Ray..PS3 (dvd player)
Polk RTA-11t-flea market
LsiC, Fxi30's
Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
Behringer Feedback Destroyer-flea market
AudioAlchemy DDE v1.0 DAC-flea market
Cambridge Audio Azur 640 CDP-flea market
Signal Cable and Kimber Kable
