CD News.....GLASS CD's
F1nut
F1nut Posts: 51,778
edited November 2006 in 2 Channel Audio
Interesting development in CD's, glass!
http://www.glasscd.com/
BTW, the price in US Dollars works out to about $800.00. :eek:
Post edited by F1nut on
    heiney9 Posts: 25,436
    Is it Windex safe?
  • hearingimpared
    hearingimpared Posts: 21,136
    Well I better gather my millions so I can replace all my LPs and CDs with the glass. hMMMMMMMMM what happens if you drop it? or hand it to your wife and it touches the engagement ring? or it gets too hot?
  • amulford
    amulford Posts: 5,020
    It would actually be a great thing for the truly historical recordings. I mean stuff like they are digitizing in the Smithsonian. No worry about corruption and crap like that they worry about now. But it would have to come WAY down in price for consumer appeal. They need to figure a way to mass produce it.
  • Shizelbs
    Shizelbs Posts: 7,433
    Is glass stable at the spin speeds in CDPs?
  • Loud & Clear
    Loud & Clear Posts: 1,538
    Too extreme tweaking
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    Hilarious!!!!!!! I wonder how it will take green marking pen on the edges?
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    Who ya' gonna' call? Myth Busters!!
    Only if Kari is part of the experiment :D
  • unc2701
    unc2701 Posts: 3,587
    Backburner:Krell KAV-300i
  • RuSsMaN
    RuSsMaN Posts: 17,986
    I just messed my pantaloons.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    Just some glass to tickle your ****
    said Barnumum Bill the Sailor.
    RT1
    F1nut Posts: 51,778
    RT1 has been at the rum......LOL
  • mldennison
    mldennison Posts: 307
    thats a good thought! anyone know who keeps the master recordings of "dark side" or "sgt. pepper" for example? it would be a big loss if in 50-100 years we have some technology that blows SACD away but they are stuck re-mastering the redbook version...
  • Emlyn
    Emlyn Posts: 4,715
    Interesting, but I don't see the point of putting 16 bit linear PCM recordings under glass when 24 bit technology is available. The technology seems to borrow the idea of replicating the glass master disc instead of transferring what's on the glass master disc to aluminum/polycarbonate/acrylic found in most commercial CD's. It would be a shame if someone bought a glass CD and played it back on a transport that has polished plastic mirrors inside.
  • reeltrouble1
    OK, no more sauce for me, I have to get working on my new earthquake proof rack to hold these babies, I will target California.
    RT1
    Rumming and rolling, I'd assume ;)
  • organ
    organ Posts: 4,969
    That looks great. I can see special recordings being released on the new disc first, and as it becomes more mainstream, hopefully every disc will be released on glass cd's.
    Will these things shatter if dropped?
    F1nut Posts: 51,778
    I have no idea, maybe it's safety glass. :p
  • jmwest1970
    jmwest1970 Posts: 846
    I don't see how they could last forever since technically glass is a liquid. Have you ever looked at original window panes in an old house?
  • hearingimpared
    The windows in old houses are usually scratched from the wind blowing little, minute pieces of debris over time against it. I wonder if it is some kind of superglass or if it is coated with something that protects the outer glaze. In any case I can't afford the offering now at $800 a pop.
    I'm pretty sure when they say recorded from the "glass master" they are talking about music archived on glass of some sort..........perhaps like this or similar.
  • amulford
    I think they digitized it from a master tape and tranfered it to disc ala burning, just like you would do for a regular disc. The difference is the glass is ultra pure and perfectly translucent, which makes for no refractions, diffraction or unwanted reflections due to impurities normally found regular CD's.
    F1nut Posts: 51,778
    Glass, when heated becomes molten, it is not a liquid. With reasonable care it should last forever. The old glass you refer to looks as it does because they didn't have the technology that is available today and has been for many years.
  • BobMcG
    BobMcG Posts: 1,585
    $851.78 to be exact as of today.:eek:
  • DarqueKnight
    DarqueKnight Posts: 6,765
    From Wikipedia Article On Glass.
    "Glass as a liquid--One common misconception is that glass is a liquid of practically infinite viscosity at room temperature and as such flows, though very slowly, similar to pitch. Glass is generally treated as an amorphous solid rather than a liquid, though different views can be justified since characterizing glass as either 'solid' or 'liquid' is not an entirely straightforward matter [3]. However, the notion that glass flows to an appreciable extent over extended periods of time is not supported by empirical evidence or theoretical analysis.
    A myth does exist that glass rods and tubes can bend under their own weight over time. To check it, in the 1920s, Robert John Rayleigh, son of the Nobel Prize winner John William Rayleigh, conducted an experiment on a 1 metre (~39 in) long, 5 millimetre (~3/16 in) thick glass rod, which was supported horizontally on two pins with a 300 gram (~0.66 lb) weight in the middle. Apart from the initial bending of 28 millimetre (~1.1 in), the position of the weight did not change until the end of the experiment, which lasted for 7 years. At the same time, another man, a worker of General Electric named K. D. Spenser, conducted a similar experiment independently. Two months after Rayleigh, he published his own results which also disproved the myth. Spenser suggested that the myth was composed before the 1920s, when the tubes were made by hand, and naturally some of them were curved to begin with. Over time the straight tubes were taken away, and only the curved ones remained. Some people probably thought it was the glass flowing.
    There is no clear answer to the question "Is glass solid or liquid?". In terms of molecular dynamics and thermodynamics it is possible to justify various different views that it is a highly viscous liquid, an amorphous solid, or simply that glass is another state of matter which is neither liquid nor solid."
    "Behaviour of antique glass--The observation that old windows are often thicker at the bottom than at the top is often offered as supporting evidence for the view that glass flows over a matter of centuries. It is then assumed that the glass was once uniform, but has flowed to its new shape.
    The likely source of this belief is that when panes of glass were commonly made by glassblowers, the technique used was to spin molten glass so as to create a round, mostly flat and even plate (the Crown glass process, described above). This plate was then cut to fit a window. The pieces were not, however, absolutely flat; the edges of the disk would be thicker because of centrifugal forces. When actually installed in a window frame, the glass would be placed thicker side down for the sake of stability and visual sparkle. Occasionally such glass has been found thinner side down, as would be caused by carelessness at the time of installation.
    Mass production of glass window panes in the early twentieth century caused a similar effect. In glass factories, molten glass was poured onto a large cooling table and allowed to spread. The resulting glass is thicker at the location of the pour, located at the center of the large sheet. These sheets were cut into smaller window panes with nonuniform thickness. Modern glass intended for windows is produced as float glass and is very uniform in thickness."
  • Emlyn
    Emlyn Posts: 4,715
    I wish we had a clear answer to this question, because every CD player I've had has had an instruction manual telling me to keep liquids away from the player. :confused:
  • organ
    organ Posts: 4,969
    Today's glass have extreme tweaking. I hope it don't blow up... eh, I need some more tape....:p .
