Biwiring my modified Advents
jcaut
jcaut Posts: 1,849
edited February 28 in Clubhouse Archives
I'm curious if there would be any benefits to using Radio Shack "in-wall" 14 ga along with Audioquest Caldera cables to bi-wire my modified Advent Legacy III's (with the Vifa ring-radiating tweeter and the crossover from a CS400i)? I'll be using my Denon 3801's built in amp to drive the low-pass part of the network, and feeding its preamp outs to the Mark Levinson Model 333 (requires a mere 2.25V for full output), which will in turn be used to drive the high-pass portion of the network. I think I'll use the Audioquest wire on the Denon (I'll terminate it with some of those screw-on banana plugs from Radio Shack 'cause I don't think it'll fit the Denon's binding posts).
I would have put this in the "Basic Wiring" part of the forum, but somehow I thought it would work better over here.
Thank you for any advice!
Jason
Post edited by RyanC_Masimo on
