Omnimount 20.0 RST
Lowell_M
I discovered today that I can't use the Btech BT77 bracket for my right rear speaker because I don't have enough room.
Can I use the Omnimount 20.0 RST bracket to mount the RTi28? It looks like it could attach to the hole on the plate on the back of the speaker. I'm not so sure of the security of this attachment though. Polk's website says the bracket will hold 15 pounds and the speaker weighs 14.
HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Post edited by Lowell_M on
Hello,
I don't recommend using the wall mounting bracket, on the speakers, in that way. The bracket could break where you are attaching the OmniMount arm. Instead use the supplied mounting plate included with the OmniMount bracket. I believe they give you wood screws and drill bit to drill pilot holes to mount the plate. This will give you a threaded insert to attach the mounting arm. You can drill into just about any area of the speaker except where the input cup is.
Regards, Ken -
Thanks Ken. I must meditate on this solution or something. I don't know if I can bring myself to drill holes in my Polks!HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Ultra Bi-Wire Speaker Cables -
Hello,
I understand, but keep in mind there are already many holes in the speaker's cabinet. Just think of yourself as the next guy in the assembly line. Your job is to install the threaded mounting plate, then do an overall examination and pass it to the next person.
Take care, Ken -
Kenneth Swauger wrote:Hello,
Take care, Ken
Thanks Ken. I got over it and ordered one last night.
Happy Turkey Day!
AaronHT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
