Humming in system
billmarcusatdcs
My system configured as follows:
Onkyo SR 702 7.1 @ 105w per pushing mids and hi's
NAD T-973 7.1 @ 140w per driving low's
bi-wired and bi amped.
Frt L/R and side L/R are rti12's with bose mini cubes wired in paralell to hi sides of rti's
Center channel is CSi5 with a mini wired in as above.
Rear channels are lsifx 2 per channel wired in paralell. Can somebody help this old ****?
Post edited by billmarcusatdcs on
'Ground Loop' is your phrase for the day. Search, read, learn.
Start by disconnecting ALL video sources from your rig, tv, cable box, sat box, game console, laserdisc, vcr, betamax.
Hum gone? Add each one back in, one at time, testing as you go, find the component causing the ground loop. Next step, try a ground loop isolator, cheater plug, etc.
If not, are you using any sort of surge suppression / power filters or conditioners?
Welcome to the boards, thanks for choosing Polk Audio! Disconnect those cubes, they are doing more harm than good. You'll get a pretty penny for them on ebay.
Cheers,
RussCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
