I-Sonic speaker hiss wth Aux input
habesct
habesct Posts: 2
edited June 2010 in Troubleshooting
I have searched the forum but have seen nothing about I-Sonic speaker hiss. Anyway, I have had this for about a month, and I am finally getting around around to testing the Aux input. When I select Aux from the I-Sonc menu, I get a noticable hiss from the speakers as if the volume is pumped way up. The hiss does not change volume regardless of volume setting.
I am going to be using that input for the sound out of a TV and I will go crazy if I can't get this worked out.
Thanks for any help.
Brian
Post edited by habesct on
  • PolkThug
    PolkThug Posts: 7,532
    edited November 2006
    Does it still hiss if nothing is plugged into the aux input?
  • RuSsMaN
    RuSsMaN Posts: 17,986
    Have you actually plugged anything IN to the input and tried it yet?
  • habesct
    habesct Posts: 2
    With nothing plugged in I get the hiss. I did try as a test to plug an iPod in to Aux 1 and it was still there.
    It is more of a background white noise type hiss.
    Thanks for the help.
  • bknauss
    bknauss Posts: 1,441
    Could you try the other aux input (aux 2) and see if there's the same hiss? Do you notice the hiss if you turn the volume to 1 on the radio?
    Brian Knauss
    ex-Electrical Engineer for Polk
  • Overlook75
    Overlook75 Posts: 2
    I posted a question on 10/7/2006 about the same hissing issue. Mine happens when playing DVD's. It seems to get worse the longer the DVD plays. Could it be heat related? The DVD does seem to be hot when removed from the iSonic.
  • pearsall001
    pearsall001 Posts: 5,092
    Call Polk customer service directly. Who better to answer your questions then them.
  • engrpas
    engrpas Posts: 6
    edited January 2010
    I have similar problem with i-sonic ES2 - there is a fairly severe hum when the AUX port is connected to an HDTV mounted directly above the radio. Here are the circumstances and some of my findings:
    - the TV's analog audio output is connected to the AUX input of the radio with shielded cable with RCA plugs
    - the hum is present whether TV is turned on or off, as long as audio cable is connected
    - hum starts around mid-level volume and increases with volume
    - there is no hum when the AUX cable is disconnected from the TV, but connected to the radio
    - when an iPod is in the dock, and the source is set to iPod, the sound is perfect (no hum)
    - when the same iPod is connected via audio cables to the AUX input of the radio and the source is set to AUX, the sound is perfect (no hum)
    - both TV and radio AC power are plugged into same receptacle
    I have been suspecting a ground loop, especially since the isonic has a power cube. Is it possible that the chassis of the isonic is not adequately grounded? Any thoughts?
  • engrpas
    engrpas Posts: 6
    edited January 2010
    One more piece of information to add to post #8:
    - when attaching a headphone to analog output of TV (same source as the AUX input to the radio), there is no hum
  • JULRUEDA
    JULRUEDA Posts: 2
    edited June 2010
    I have the same problem for noise when connected aux input, please i need help with anything then take me is that noise
