mild humming from sub
rosey
rosey Posts: 1
edited November 2006 in Troubleshooting
I have been noticing a mild humming fro my sub....I have upgraded my sub cable to the monster brand and the humming did stop for a while but has started again
any ideas
Post edited by rosey on
  • ohskigod
    ohskigod Posts: 6,502
    try jiggling the cable in the back of the amp, see if there is any changes. if there is, its a connection issue, probably at the plate amp.
    my money though would be at a ground loop. a quick way to diagnose it is to take a cheater beater plug (what you would use to make a 3 prong plug [ground] fit into an older 2 prong outlet [without ground]). just plug the sub into the cheater beater and the cheater beater with sub plug attached to the wal. if the humming goes away, it a ground loop.
    I still use a cheater beater for my sub since no matter how i arrange my cables, the damn humming wont go away.
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
