RT1000i
Ruknani
Ruknani Posts: 2
edited March 2012 in Troubleshooting
On one of my RT1000i mid/bass driver died out. has a model # MW7200. Upon visiting my local Polk Dealer he suggested that I can replace it with a different driver model # RD7217-2 which he has in stock and sell me real cheap.Almost half the price of MW7200 if ordered directly from Polk. But I am not sure if its the right replacement part. Please help.
Post edited by Ruknani on
  • ohskigod
    ohskigod Posts: 6,502
    edited November 2006
    sounds like he is swapping it from another speaker. sounds a little fishy to me. I would just order it from polkaudio. tell them your a clubpolk member and it takes some bucks off.
    actually, if you ask polk customer service about that part number the dealer gave you. they will most certainly give you honest insight. call customer service.
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    right on Lou.
    +1
  • amulford
    amulford Posts: 5,020
    Absolutely. Check first. If it's not the right one, you'd be wasting your money.
  • Ruknani
    Ruknani Posts: 2
    I have Polk HT setup for more than six years now but never knew about this forum and so many good people who are ready to help. I will go ahead and order the proper replacement part.
    Thank you guys for all your help.
    S. M. Ruknani
  • janmike
    janmike Posts: 6,146
    Welcome to the forum. Great gang of folks here.
    Michael ;)
    NORTH of 60°
  • danger boy
    danger boy Posts: 15,722
    does Polk still carry those blue drivers? I hope so..i may order a couple spares if they do. the RTXXXi's use them
    PolkFest 2012, who's going>?
  • amulford
    I think they do. There aren't any more tweeters, though...:(
  • Quickvibe
    Quickvibe Posts: 1
    edited March 2012
    The mid woofer on one of my RTi10 is not working properly. I removed it to look at the Part# It is RD 7217-2 . The Part catalog says RD 7217-1. Does anyone Know why this is ? Or what the differance is. I am not sure the problem is the speaker. Could it be the crossover? It distorts sound on a certian band with. I would appreciate any advice and if this is common with this model.
