speaker humming noise
band1t
guys, hope someone can assist, i really have no idea where to start.
The problem is more so with one, but exists in both its a humming sound that is quite noticeable. the speakers are R20 roughly 4 years old, connected to HK AVR 225. If i have missed something, please let me know......
Thanks.
Thanks.
Post edited by band1t on
Sounds like a ground loop. Do a search on ground loop and see what you come up with. Have you added any new componets recently? If you disconnect them does the humm go away? They can be a pain to trace down, but are worth the effort.
Thanks Michael, nothing additional has been added, just turned it on one morning and noticed it.
loose ground
