blown speaker?
smoz
Hi
I have an old pair of 5b's. Bought them when polk first came out. they were a new company at the time. well my problem is there is no bass or mid coming out of one of my speakers, sound is very low. could it be the crossover? i'm guessing the speaker is blown any help would be great.
thanks, steve
thanks, steve
Post edited by smoz on
It's most likely the mid woofer, polk still sells replacments if you call CS and also mention your a club polk member you get a discount..
welcome aboard!!MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
I think they have a set of fuses on the back binding post plate. Check that and see if the fuses are good. Also, check for oxidation on the fuse ends and holders.Political Correctness'.........defined
President of Club Polk -
Thanks, i believe it's blown. i compared the bad one to the good one.and the good one makes a thumping sound and the bad one seems like it is stiff, no thumping sound. so i will be replacing it.I will call polk tec on monday.
steve
