LSI 15 problem
Jockos
Since I first purchased my LSI 15's the left speaker always seemed more louder & dominant. A tiny hole was found in the tweeter and a replacement was sent. There was no difference in sound. I've tried swapping amps, preamps and of course left and right speakers. The left still seems more dominant and not as crisp. Any suggestions?
Jockos
Jockos
Post edited by Jockos on
Where these new or used? Do you know the history of these speakers?
If nothing else I would contact Polk Customer Service.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
It's your room acoustics.Political Correctness'.........defined
President of Club Polk -
Right on Jesse, I didn't see or comprehend he also swapped speakers. DUH
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
The Speakers were new, and I also made a room placement change about a year ago.
just turn one up to match the other one... and you're good to go. i have the same problem with my fronts. the left is set at -1 while the right is set at +2 otherwise i can tell the front soundstage is way off.PolkFest 2012, who's going>?
db, i don't doubt that changing the balance works across the frequency spectrum for some rooms and listening styles, but in my room the acoustics throw off the image at differing degrees depending upon the frequency. in other words, say, the center image is mostly stable with a particular vocalist, but as different notes are struck the image shifts towards one speak and the tonal balance will change to the point where, for example, sibilance will creep in on one side.
listening position, placement (room contents and speaks), toe and treatments all help, but waf is low for moving room contents and treatments, so i do have to juggle stuff a bit when i want the best sound i can get.
jockos, there are threads on the forum where folks have found this to be a speaker problem and polk helped them correct it, but i agree with others that this is more often room acoustics. it could also be a hardware problem too.
for hardware and speaker problems, you could try troubleshooting by doing things like swapping left and right wires and cables at different points in the system while leaving the speaks in the same position and also swapping the speaks while not changing wires to pinpoint the problem. it would probably be helpful to use the same music (a cut that always produces a strong imbalance) throughout the tests so you have a reliable reference to gauge your results.
good luck and enjoy the process. you can learn alot about room acoustics and your speaks while you try to sort this out. in the end, if this is room acoustics, you should be able to get alot more from your system from insights you gain from thinking about and working on this problem.
Jockos wrote:The Speakers were new, and I also made a room placement change about a year ago.
How about you describe or better yet post a pic of your set up along with measurements.Political Correctness'.........defined
Thanks, I'll try a couple more variations of position and equipment swapping and even have different people listen. I'll post the results. This could take awhile.
Jockos
