Sudden trouble with my trusty PSW50
dtrucken
've had a PSW50 for a long time, and it has worked great. Recently, it started making a strange buzzing sound, sorta like the music is piped through a child's kazoo or something.
Is there any hope I can repair it, or should I start over?
Post edited by dtrucken on
I think that means the voice coil is going bad. If thats the case, you'll need a replacement speaker or get a new sub.2 Channel
Vandersteen 3a Sigs
Music Reference RM-200
Hovland HP-100
VPI Scout w/ Benz Ace
Rotel RCD-1072
Cardas Golden Reference Speaker Cables
Cardas Golden Reference Interconnects
Cardas Golden Power Cords
PS Audio UPC-200HB
Black Diamond Racing Isolation -
Is this something that just happens after 8 years or so? :-(
I don't mind replacing the speaker, but, where do I get a replacement?
Is it likely that other things (like the amp) will also fail soon? -
I called Customer Support, and while I could still get the replacement driver, it seems that for not that much more money purchasing a new PSW10 was a better option for me.
Does anyone want a slightly-busted PSW50?
dave.truckenmiller@gmail.com -
Quick thing to try: I bought a used PSW50 for $3 at a garage sale with the same issue.
I merely turned the woofer upside down into a different mounting orientation and the issue went away.
"Good luck."
