Anyone know about these Polks?
Early B.
Early B. Posts: 7,900
edited September 2006 in Speakers
I've been checking these out:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ih=014&item=330025287151&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1
Never seen them before. Didn't realize Polk made SDA bookshelf speakers. Can anyone tell me the specs? How do they sound? When were they made? Is this a good price? NOTE: I e-mailed the seller and he doesn't know the specs.
Thanks.
"God grooves with tubes."
Post edited by Early B. on
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    Early,
    I cant see the link at work, but I have a set of the SDA CRS, the original with the two sl2000 tweets. They sound marvelous and can be modded to extremes, I think when all was said and done I was around 300.00 mark with stands and in excellent condition.
    Hope that helps a bit, but I know a bunch of guys here have them, they are really all the SDA you could want.
    RT1
  • ESavinon
    ESavinon Posts: 3,067
    Those are the sda crs. 1st generation.
    They're excellent.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • Early B.
    Thanks, fellas.
    I'm really interested in knowing how low they go. If I bought them, I'd use them for HT fronts.
  • reeltrouble1
    Mine are in a HT bedroom rig now being used as fronts, they are supplemented by a psw250. I might have the specs if no one knows off hand, I will see if I can find them Seo sent me a manual if I remember right.
    RT1
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
  • reeltrouble1
    If I remember correctly the original CRS are 4 ohm, blade/blade.
    RT1
  • BlueMDPicker
    According to Dr. Smith's fine compilation:
    FR - 31 Hz to 26,000 Hz
    Imp. - 6 ohms
    Eff. - 92 dB
    Tweeters - 2 x SL2000
    Stereo driver and dimensional driver - MW6503
    PR - SW102
    Twin blade interconnect
  • Emlyn
    Emlyn Posts: 4,715
    Seems a fair price considering you probably wouldn't need to upgrade the tweeters and the cable is included. If you do get them, ask for them to be boxed and shipped separately with plenty of bubble wrap, not just packing peanuts. You might also want to see additional photos. I'm not sure if Polk made their stands for the originals, but the PartsExpress 24" stands work well with the CRS series.
    billbillw Posts: 7,547
    Early, That pair has been listed 3 times (including the current auction). Didn't sell for $350. Notice its not an auction, but fixed price. Overpriced in my opinion. They have SL1000s in them. Not as easy to upgrade as the later versions.
    If you like that pair, check out this pair, ending tonight
    http://cgi.ebay.com/Vintage-Polk-Audio-SDA-Compact-Bookshelf-Speakers_W0QQitemZ320022871769QQihZ011QQcategoryZ71572QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
    A true auction, should give you an idea of what the going price is.
  • Early B.
    Thanks, Bill. I'd rather buy speakers that work. In your link the seller says that one of the tweeters in each speaker is out. He also doesn't have the cable. These should sell at a low price to someone who enjoys repairing speakers.
    I didn't read the whole auction. Didn't notice that, or how scratched up they are.
    By the way, most likely, the tweeter's that are not working are because the interconnect cable isn't being used.
  • read-alot
    read-alot Posts: 812
    anonymouse
    Polkazoid
    says
    "This should make no difference to the tweeter function. The tweeters are not wired into the SDA cable circuit at all"
    http://www.polkaudio.com/forums/showthread.php?t=43234
    polkaudio SRS (rdo194 x 8)
    Dodd ELP (separate power supply)
    JC 1 blocks ( strapped )
    Rega Apollo
    MIT (speaker cables) Outlaw (ICs)
    polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • dorokusai
    dorokusai Posts: 25,576
    That particular model does have the tweeters wired in the SDA circuit.
  • read-alot
    OK, Thanks for clearing that up.
    Rega Apollo
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • DarqueKnight
    DarqueKnight Posts: 6,765
    Thanks.
    Those are the "freak" SDA CRS's with the SL1000 tweeters. I'm surprised someone hasn't snapped these up just for the tweeters alone.:) Some people think the SL1000 sounds better than the SL2000 and the latest silk dome tweeter.
    As billbillw stated, the subsequent tweeters (SL2000 and silk dome) are not drop in replacements for the SL1000.
  • Early B.
    I e-mailed the seller and asked to see additional pics, and he'll provide them tomorrow. He said they are in 7/10 condition, but I'd like to see what they look like before pulling the trigger (if they're still available). They gotta at least look presentable.
  • dorokusai
    I would presume they forgot to take the crazy pill that day, as those tweeters are equally horrible. That's just me, simply due to a better tweeter being available. It's a shame it's not framed smaller...maybe the DEI thing can get the manufacturer to press another, smaller frame. nudge nudge wink wink eh
    F1nut Posts: 51,778
    Gotta agree with Doro. Silk domes are the sheeetz!
  • Early B.
    Thanks for the insight, fellas. I'll pass on these.
  • reeltrouble1
    I have heard the SL1000, I would change it.
    RT1
