Single SR 10 sub. Which amp?
Toxis
I'm considering either the Xtant 6.1 (600w mono) or the Diamond Audio D61000.1 (500w @ 2ohm) to run a 4 ohm DVC SR 10" sub. I'm considering the Xtant for the SQ and a tad more power but it's also gonna cost me about $100-140 more. Is it worth it??? What do you guys think? I want great SQ but the potential for some output. OEM deck BTW, nothing aftermarket.
Post edited by Toxis on
Of course the best choice would be the 500.1
BUT, Xtant effing rules!
If your choice is between Xtant and anything else, get the Xtant.
Ultimate build quality, tons of clean power, a host of tuning features and very cool looks.polkaudio sound quality competitor since 2005
I could get the Polk 500 but I have a feeling they are going to be remodelled fairly soon so I'm not sure about that yet. I can get it for $100 less than the Diamond and $110 less than the Xtant. My prices were wrong earlier (off top of head, not actually looking at my prices). The Xtant is $10 more than the Diamond. I could get the Diamond and a dual 2ohm sub to get a full 1kw. HmmmmmmNever kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
Xtantpolkaudio sound quality competitor since 2005
I think either choice would be a good one.Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
so would you rather put 500w to it at 2 ohm or 1k at 1ohm? I'd have to order the dual 2 ohm while we stock the dual 4. I'm leaning towards the Xtant with the dual 4. Building a box that sits "sideways" and is mounted to my rear deck. Then have it fill a chamber that is now using the OEM sub cutout as a way directly into the car. Have it sealed off so the trunk gets as little to no sound as possible. I'm sure 500w will be plenty for that.Never kick a fresh **** on a hot day.
If placed in the proper enclosure, 500 watts will be more than enough to get the sub going.Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
Toxis wrote:so would you rather put 500w to it at 2 ohm or 1k at 1ohm? I'd have to order the dual 2 ohm while we stock the dual 4. I'm leaning towards the Xtant with the dual 4. Building a box that sits "sideways" and is mounted to my rear deck. Then have it fill a chamber that is now using the OEM sub cutout as a way directly into the car. Have it sealed off so the trunk gets as little to no sound as possible. I'm sure 500w will be plenty for that.
They dont have a dual 2 ohm SR sub. Its either single 4 ohm or dual 4 ohm so the 1 ohm operations aint gonna work unless you buy a pair of DVC subs.
The Polk C500.1 will make 600 watts RMS and the Xtant will make a good bit more than 600. Id say youd be closer to 700 with the Xtant.polkaudio sound quality competitor since 2005
No need to get close, as you will get all the performance you need before giving that sub 700 watts.Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
word up... now I just have to fight the urge to upgrade the fronts.Never kick a fresh **** on a hot day.
Toxis wrote:I could get the Polk 500 but I have a feeling they are going to be remodelled fairly soon so I'm not sure about that yet.
That's probably not a correct feeling... just a subtle hintBrian Knauss
ex-Electrical Engineer for Polk -
And Polk > Xtant. Its been proven thousands of times!Brian Knauss
..........................Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
bknauss wrote:That's probably not a correct feeling... just a subtle hintcomment comment comment comment. bitchy.
i have the sr124-dvc and am going to use my zapco c2k-3.0 rated at 600 watts into 2 ohm bridge. in real life it puts out about 700 watts. its expensive, but they are rock solid amps with a damping factor of over 1000 to really control cone movement.kenwood excelon kdc-x991 h.u.
Rockford Fosgate 360.3 DSP
Rockford Fosgate POWER1000 running entire system
Image Dynamics IDQ12 Sub
Morel Elate 6 front stage -
brettw22 wrote:Are there any plans maybe in the somewhat near future to release a line of amps that is styled moreso to the SR line than the momo?
subtle hint: don't hold your breath.Brian Knauss
killerb wrote:i have the sr124-dvc and am going to use my zapco c2k-3.0 rated at 600 watts into 2 ohm bridge. in real life it puts out about 700 watts. its expensive, but they are rock solid amps with a damping factor of over 1000 to really control cone movement.
I too have amplifiers with very high damping factors.
Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
Damping factors... great on paper, worthless in real life.Never kick a fresh **** on a hot day.
Damping factor is actually important... but its unimportant to most consumers since it doesn't generally affect anything out on the market and there are too many ways to post its value.Brian Knauss
Isnt it like THD specs in that while true .004% is better than .04% but it doesnt matter because you cant hear anything below 1%?
I kinda figure any damping factor over 50 or so and youre fine.polkaudio sound quality competitor since 2005
I will still stick with my Arc amps
Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
MacLeod wrote:Isnt it like THD specs in that while true .004% is better than .04% but it doesnt matter because you cant hear anything below 1%?
You're on the right track. But 50 measured which way? There's the problem right there... hard to quote a number that means anything when there are different ways to measure it.Brian Knauss
My understanding is that its measured by the load impedance divided by the amps internal impedance?
If thats the case and most amps that Ive seen specs on have around 1 ohm or less internal resistance and a typical load is 4 ohms, a typical amp with these numbers would have a damping factor 4/1 = 4! Maybe if the amp had .05 internal impedance youd have 4/.05 = 80. So basically an amp would have to have an insanely low .005 ohms internal resistance in order to have an 800 damping factor! And to my knowledge, there arent any amps with that low of internal resistance.
Isnt this right or have I missed the boat completley?
Remeber, I have an EXTREMELY limted understanding of this so be gentle!polkaudio sound quality competitor since 2005
http://www.classic-audio.com/marantz/mdampingfactor.html
this explains alot about the damping factor subject. i didnt know speaker wire size can play a big part in damping factor values. i dont know anymore but the amps i like and buy always had very high damping factors, like zapco and u.s. amps. i just like quality amps, buy it once and it lasts.kenwood excelon kdc-x991 h.u.
heres another good one.
http://www.audioholics.com/techtips/audioprinciples/amplifiers/dampingfactor.phpkenwood excelon kdc-x991 h.u.
Good links.
I think I understand it now.polkaudio sound quality competitor since 2005
yeah i finally do to. there is virtually no change in decay time through a wide range of damping factors which is surprising to me. good info for all.kenwood excelon kdc-x991 h.u.
well xtant is consider high quality stuff the price of it says alot and they did their research in car audio its ur choice.Whatsoever thy handfindeth to do, do it with thy might; for there is nor work, nor device, nor knowledge, nor wisdom, in the grave, whither thou goest.
the new xtant isnt of the same quality as the oldschool xtant.kenwood excelon kdc-x991 h.u.
