Shuguang KT88's
Early B.
I have been itchin to try a different quad of power tubes in my Jolida 502 integrated amp. Currently, I use Electro Harmonix KT88s. The EHs are highly regarded as an overall great performer. The major criticism is that they sound like solid state. After doing some Internet research for several months, I decided to try a set of inexpensive Chinese tubes the Shuguang KT88s. [NOTE: Shuguang makes re-branded tubes for Groove Tube, Ruby and Valve Art, to name a few.] According to what Ive read, they are preferred by many Jolida owners and are supposed to sound very tube-like. This comes primarily from informal feedback of Jolida owners as reported by the folks at Response Audio who modify Jolida amps.
My Shuguang KT-88's arrived last week. Since the EH KT88's are the only power tubes I've used thus far in the Jolida, I don't have any other basis for comparison. The first thing I noticed is that they have better bass than the EH KT88's. Otherwise, they sounded equally as good as the EH's right out of the box. That was a good sign. After a while I noticed that they are not quite as analytical as the EH's. On some music the head bobbing and toe-tapping increased. I should mention that, with the exception of the bass, the other differential characteristics I am describing are very slight.
The level of detail is about the same, but the vocals are more forward and natural sounding on some recordings with the Shuguangs. Eventually I realized the Shuguangs have a slightly larger soundstage and, in general, are a bit more musical. However, the build quality and aesthetics are not as good as the EH's. The EHs are also a bit more refined and produce more a tad more clarity with instruments such as piano and cymbals. Nevertheless, I prefer the Shuguangs over the EH KT88s, primarily because of the better bass and overall musicality. I cant fully describe it, but the Shuguangs simply have a different presentation than the EHs that I find more pleasing.
It took me two years to finally try a different set of power tubes and Im glad I did.
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
Post edited by Early B. on
awesome, when ya find something ya like.. its hard to try something new. and if ya go crazy and try to many tubes its hard to keep track of the changes.. glad ya found a better choice with one changeMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
Cool! Sounds like a good match with your system. Let us know what you think after using them for awhile. I always find it interesting to really get used to something new (a few months) then switch back to the old. The results are quite often not the same as I originally thought. Sometimes its massive, sometimes nothing.
Awesome. Glad you're enjoying tube rolling. I've also had great success with Chinese tubes. I tried the Shuguang EL34B and the sound is very nice. It was too analytical at first until I installed some warm and juicy sounding tubes in the pre. The Chinese are making some great tubes. I'm gonna give their 12AU7 and 6922 a try.
Plenty to choose from in new production tubes - Tung Sol 6550's, Ei KT-90's, Ei elite 12AU7, 12AX7, 6DJ8, EH KT-88's, etc. I tried some Chinese 6L6GC tubes recently that didn't get along with my amp but they did sound nice while they lasted. I've also got some Chinese 12AT7 triple mica Mullard knock-off tubes that sound sweet.Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
Cool, changing tubes is one of those things I struggle with, glad you like em. The musicality you mention is something that strikes home for me. I know each tube distorts the signal just a bit differently, finding the one that pleases your ear is great/
RT1
