Ground Loop /Balanced Interconnects!
wingnut4772
:eek:
I am still in the process of re-doing my HT and I finally got my balanced DH Labs Air Matrix interconnects. I hook them up and....Hummmmm.:eek:
So, I go throught the whole thing of unplugging everything. The first suspect the Sat box. I unplugged everything with no improvement. The only thing in my system that made a difference was removing the HDMI cable from the Anthem D2 that is coming from the Sat but there is still an audible hum. I never got any noise with my RCAs. Dead quiet. So, unless anyone here knows why this is happening I am returning the XLRs for my good ole' RCAs. They sound phenominal anyway...I don't know why I felt the need to try the balanced.
Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Post edited by wingnut4772 on
I don't think I have that switch.... I will lookSharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
anonymouse wrote:I would use XLR only if you have very long runs. Having said this, on my Rotel amp there is a switch to go from balanced to unbalanced. Do you have the same? Is it in the right position?
Good suggestion, had the same problem with my amp,after moving it one of the switches was inadvertently flipped on the right channel,went through 2 sets of IC's before I figured it outJC approves....he told me so. (F-1 nut) -
Nope. No switchesSharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Screw it. They are going back.:mad:Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Stick with the Rca's darla and put your mind on more important things in the systemMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
The only reason I got the XLRs is because another D2 owner recommended them over the RCAs but I really can not imagine that they sound better over a 1 meter run and in my system thery certainly don't.:pSharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Let us know if you get the hum with the RCA's, even if you didn't have it before. Ground loop hums can drive you crazy to find. They are usually cheap to fix once they are finally found.Carl
I hate fighting ground loops. My gears are all RCAs. Everything I switching, the battle starts. I thought XLRs are immuned to ground loops, no? Or XLR has it's own quirky daemon?
-fredv- -
See, I was in a different boat. I have the hum if I use the RCA's. Once I went to the XLR cables, hum was gone.Money Talks, Mine says Goodbye Rob!!!!
schwarcw wrote:Let us know if you get the hum with the RCA's, even if you didn't have it before. Ground loop hums can drive you crazy to find. They are usually cheap to fix once they are finally found.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
