Quick Cable question...
Sax
Sax Posts: 70
edited August 2006 in 2 Channel Audio
for anyone whose been watching my system progress (for starters, hopefully you're having as much fun as I am :-P) I have another upgrade I am now debating. I want to get a better speaker cable, however I'm debating between a few.
For starters, I'm currently using Sound King 10awg oxygen free copper just good 'ol cheap zip wire, terminated with 24ct gold plated banana plugs.
I was thinking of going with either the Cobalt "Ultimate Speaker Cable"
http://www.cobaltcable.com/pair_speaker_cable.htm
or the Zebra sp10sd
http://zebracables.com/sp10sd.html
If anyone has their input on personal experience with either of these two, or, a recommendation in the same price range, I'm all ears. I'm leaning towards the Cobalt, however the zebra is a tad cheaper.
Monitor 5b
RTA 11T
Rega Planar 2 (1970's)
Adcom GFA-545II
Post edited by Sax on
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2006
    Why isn't Signal Cable an option? I just checked them quickly, but it looks like the Zebra or Signal would be cheaper.
    What are your requirements? Length?
    I built an HT for a buddy based on Cobalt(BULK), and he hasn't complained to date.
    BFA, Scosche and Vampire Wire are all top notch terminations.
  • marvda1
    marvda1 Posts: 4,950
    edited August 2006
    also check out www.elementcable.com and www.audioartcable.com
    both make great cables.
    Puritan PSM156
  • Sax
    Sax Posts: 70
    edited August 2006
    I'm going for a pure 2 channel set up here... we're talkin 2-3 meter lengths tops. probably 3 meter it'd give me some room to play.
    Monitor 5b
    RTA 11T
    Adcom GFA-545II
