Comments on PSW10 Sub with SurroundBar?
replicants
replicants Posts: 3
edited August 2006 in Speakers
I posted this in the subwoofer forum but also wanted to get comments here if possible. I already have the PSW10 from a previous setup and wondered if anyone had used it with the surround bar? Any comments are greatly appreciated.
Post edited by replicants on
  • mantis
    mantis Posts: 17,201
    edited August 2006
    If you can hang it on the wall and have sidewalls and a back wall, it works ok, you can do alot better with other polk setups.
    The surround bar is for places where you can't get rears. Where the room is a wiring problem. They also work good in a bedroom.
    Setup is critical. I have Installed a few and have mixed feelings. In a medium size room with no back wall and high ceilings, it didn't work so good. In a bedroom med size with 4 walls, it works pretty good and sounded pretty good.
    Dan
    Dan
