Bargain t.v. sellers
univera
I'm still on the never ending search to narrow and pick a 40" lcd tv. I found a site on line that is a couple hundred dollars cheaper than other sites. Naturally, I am skeptical and concerned about sending $2,000 or more to an internet based site. They are $500.00 below Tweeter's "sale" price on the Sony KDL-V40XBR1 I am looking at. Just curious if anyone has experience with these New York based outfits. Also curious if only one HDMI connection is something I might regret down the line.
UNIVERA
Historic Charleston SC
2 Channel:
SDA-SRS's RDO tweets
Biamped Anthem 2 SE's w/1970's NOS Siemens CCA's
Anthem Pre 2L w/E.harmonix platinum matched 6H23's
CDP- NAD C 542
HT setup:
AVR: NAD T 773
Rears: Polk LC80i
DVD: Toshiba 3109 dual tray
Subs: Velodyne and M&K
T.V.: Sony KDL-52XBR4 w/Vans Evers Clean Line Jr.
Conditioner: Panamax M5100EX
Master Bedroom Sony 40KDL-XBR3
"I love it when a plan comes together." Hannibal Smith, The A-Team
2 Channel:
CDP- NAD C 542
HT setup:
AVR: NAD T 773
Rears: Polk LC80i
Post edited by univera on
What's the website?HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables -
If it don't feel right, it ain't.
If you're looking to buy online, call the brand manufacturer and ask if their warranty will still be honored if you buy from an Online Dealer. Many brands, such as LG, will tell you that buying online will void your warranty. Others will require you to have a receipt of purchase listing the serial number of the TV (something online dealers will never do). Now if you're in the US manufacturers are required by law to service your TV, but they're gonna make you hire a lawyer first.
and like Wall Street said, if it don't feel right, it aint. -
Check out http://www.resellerratings.com/ to read reviews of various stores
depending on the brand, make sure the online retailer is an authorized dealer
New York based internet TV retailers:
AVOID AVOID AVOID...
Trust me, about 90% of them are SHADY. They try to make you buy all kinds of "options" (like the remote), and if you don't they cancel your order (but tie up the credit for another week or two)
Same thing goes for cameras.
So google the name of the seller and unless they've got a pristine reputation, it's not worth the cash.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
Some are okay, but I am leary of most. If its just a few bucks, don't do it. If you don't feel right about it, wait until the prices come down or wait until you have some more scratch saved up.
The 40XBR1 is discontinued so you should see rapid price drops on it soon. I'd hold off.
the prices are dropping crazy fast at B&M stores. Shop local and you will always have service. 'Nuff said.Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
I purchased a big screen TV online from Montana. Hated the TV and had to send it back. Big wast of time and $$$. Buy local if it's something difficult to send back. Only one HDMI? IMHO that's a problem unless you plan on purchasing a new AVR that has HDMI imputs. Two HDMI is the minimum you should have for everything that's currently available: DVD, HD-DVD, BRD, DireTV, Dish Network, Digital Cable, etc.univera wrote:Just curious if anyone has experience with these New York based outfits. Also curious if only one HDMI connection is something I might regret down the line.
Good luck
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
Local B&M will more than likely do price protection too.
