so I probably did something a bit frowned upon to my 535
nadams
nadams Posts: 5,877
edited August 2006 in Electronics
I've been having problems with the switches that control the A/B speakers. Especially with the "A" selector, it would drop the right channel a lot. If I wiggled the switch a little bit it would be okay, but it would always drop out again.
So I pulled the switch apart and found that the contacts inside had actually gotten somewhat burnt from the power going through them for the past 20 some years. I tried cleaning them with CAIG DeOxIT, and treating them with ProGold afterward, but nothing seemed to help. So, I gave it the old "screw it" shrug, cut the wires from the "A" channel, and spliced and soldered them together to create a permanently "on" channel.
The only downside that I see, was that I was unable to get the "B" selector switch back together properly, so now I can only drive one pair of speakers (the SDA's) with this amp. I suppose I could cut the "B" channel wires and do the same thing with them, but then I'd have to physically unplug one set of speakers to use the others. The only other speakers I was driving with this amp were the R15's I have sitting on my desk, so I may have to get a Sonic Impact T amp or something to drive them with.
I figured that the hardwired method would be better for the SDA's anyway, after seeing the small contact patch, and thin metal that the switches contain. You'd think they would have to use better materials in those switches...
Ludicrous gibs!
Post edited by nadams on
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited July 2006
    Switches and connectors are the top two areas where audio manufacturers cut corners.
  • nadams
    nadams Posts: 5,877
    edited July 2006
    Makes sense I suppose. I guess I could try to find better quality switches to replace the factory ones with to restore the amp to full functionality (though the switches themselves are soldered to a circuit board, which would make it harder). While I'm at it, I really should get some nicer RCA jacks for it from diycable.com. I never know which style to buy, though.
    I realised, after thinking briefly, that I wouldn't be able to get the B selector switch to work by itself unless I took a jumper wire from the switch to the ground in the pair that I cut out... being a common ground amp and all....
    Ludicrous gibs!
  • DarqueKnight
    edited July 2006
    Send an email to Adcom (info@adcom.com) and ask who was their vendor for the switch. The vendor may have an identical sized switch that is higher quality. Also, ask Adcom for a recommendation on higher quality RCA jacks and a power switch.
  • dorokusai
    dorokusai Posts: 25,576
    edited July 2006
    The RCA's are either PCB mounted or chassis mounted...one look should solve that problem.
  • nadams
    nadams Posts: 5,877
    edited July 2006
    The RCA's are chassis mounted, coupled as a pair and screwed through the back of the amp. I'm guessing that I can just buy any rca's that have the nut to tighten them to the chassis and I'll be okay...
    I will get in touch with adcom on the switches...
    Ludicrous gibs!
  • Sherardp
    Sherardp Posts: 8,038
    edited July 2006
    it sux but why cant you just send it in and have them do the work, test it, and send it back. that way its sure to work correctly and they may even warranty the work.
  • dorokusai
    edited July 2006
    Yep, easy project.
  • unc2701
    unc2701 Posts: 3,587
    edited August 2006
    If I remember right Adcom charges about $100 just to look at it and if they warantee the repair it's only for like a month. Now that $100 will go to the cost of the repairs that they deem needed, but you could get some badass jacks and a high quality switch for that price.
    Backburner:Krell KAV-300i
  • nadams
    nadams Posts: 5,877
    edited August 2006
    Ordered my Cardas jacks from DIYCable.com
    Still haven't heard anything via email from Adcom... I may have to call them.
    Ludicrous gibs!
  • unc2701
    edited August 2006
    Yeah, give them a call... the girl they used to have answering the phones was awesome.
    heiney9 Posts: 25,451
    edited August 2006
    Uhmmm.......don't forget about the crappy speaker terminals on the MK I series. That would be my first upgrade, I hate those things and I don't even own a 535 MK I right now. If you're going to do it, "git 'er done all the way", IMO of course.
    edited August 2006
    Also, if you send to Adcom to have the work done (not repairs) it won't be worth it. It will cost you as much as a another used unit. They would do a great job, but it'll be expensive. If you can't tackle the project yourself any competent electronics repair shop should be able to do it for about 1/2 the cost Adcom would charge. Nothing wrong w/ sending it to the manufacturer for bonafide repairs, but for an upgrade like this it isn't necessary.
  • dorokusai
    edited August 2006
    That's gonna be one hot looking piece of **** when your done.
  • nadams
    nadams Posts: 5,877
    edited August 2006
    I just got a response from Adcom on the switches. They're $14 ea. I'll be calling them to order sometime soon. As for the speaker terminals, I realise that they suck, but I'm not sure how it would work to replace them. They have solid pieces of metal running down to a circuit board, rather than just being wires. Seems like it would be hard to find a matching part...
    Ludicrous gibs!
