Using an External DAC or not
joeparaski
joeparaski Posts: 1,865
edited July 2006 in Electronics
I've hooked up my brand new Emotiva LMC-1 pre/pro and wondering if I should use the built in DAC (24bit/192khz) or my external MSB Link DAC 11? Right now I set it up using the external DAC, since I just recently bought the darn thing.
The LMC-1 manual also says that I should use the coax or optical inputs whenever possible as these will carry any encoded multi-channel audio format such as Dolby Digital or DTS.
But doesn't the external DAC send these signals from its analog outputs which would then go to the pre/pro analog inputs? (using CD digital out to DAC digital in)
This unit is my most modern unit in my otherwise 80's equipement and I've got a lot to learn. Like what do I use when listening to cd's...pro logic? dolby digital? Dolby digital ex? DTS? DTS-ES? DTS NEO:6? Virtual? Matrix? and what do I do with dvd's and their corresponding setups? Do I need to look more closely at the packaging when buying media?:o
Oh, and I love the fact that I don't have to get up to raise or lower the volume.:D
Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
Post edited by joeparaski on
  • joeparaski
    edited July 2006
    ***Sorry to say, you wasted your money, that MSB dac is old and outdated, you should use the built-in dac.
    ***LIsten to what the manual says, it is the end all definative answer. Your manual doesn't mention anything about usning an external DAC, therefore it is impossible to use one...junk the MSB.
    ***Who knows and who cares? Junk the MSB and listen to the manual.
    ***Yes you do have a lot to learn. The first thing you need to learn is that you have to junk all that crappy 80's stuff and move into the real modern world like the rest of us here, only THEN can you post questions that we can answer. As for all the other techno stuff....you need to get off your butt and search and read up on all that, do you think that we're here to spoon feed you information just for the heck of it?
    ***See, you're already learning. Modern equipment rules, your stuff from the 80's suck! I suggest you find a forum dedicated to 80's crappy gear and disco, they go well together.
  • HBombToo
    HBombToo Posts: 5,256
    edited July 2006
    Joe
    is everything ok over there?
    ***WAREMTAE***
  • steveinaz
    steveinaz Posts: 19,538
    edited July 2006
    Get Joe a beer, he's arguing with himself....
    Your MSB would sound better, I would imagine...try it and see for yourself. I don't know schitt about all that Dolby this, DTS that stuff, I'm 2-channel baby.
  • halo
    halo Posts: 5,616
    edited July 2006
    Talking to yourself is said to be a sign of madness. Posting to yourself has got to be worse. If you live near Joe - RUN!!! RUN AWAY NOW!!!!!!!!!
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited July 2006
    He must have flown too close to the sun in one of his contraptions!!!
  • Dennis Gardner
    edited July 2006
    Using the External DAC will require coax or fiber into the DAC and RCA outputs into the analog multi-channel of the Emotiva. This bypasses the usage of the Emo's DAC and allow you to choose 2 channel or multi channel.
    I would try both DACs to determine a preference. I use an external DAC for my 2 channel mode running into my tube pre, but rely on my HK through digital coax to decode the movie codecs.
  • joeparaski
    edited July 2006
    I figured since nobody responded to my questions I'd answer them myself.
    For those that did answer, thank you for your suggestions. I'll try and figure out all the other stuff later.
  • Holydoc
    Holydoc Posts: 1,048
    edited July 2006
    My advice is to start drinking heavily. I see a Jerry Springer show dedicated to you soon.
    Holydoc (Home Theatre Lover)
    __________________________________________
    Panasonic -50PX600U 50" Plasma
    Onkyo -TX-NR901 Receiver
    Oppo -Oppo 980HD Universal DVD Player
    Outlaw -770 (7x200watt) Amplifier
    PolkAudio - RTi12 (Left and Right)
    PolkAudio - CSi5 (Center)
    PolkAudio - FXi3 (Back and Surround)
    SVS - PB-12/Plus (Subwoofer)
    Bluejean Cables - Interconnects
    Logitech Harmony 880 - Remote
  • halo
    halo Posts: 5,616
    edited July 2006
    Jerry! Jerry! Jerry! Bleeep! Bleep! Bleeeeeeeeeeeeeeeep! Bleep! Bleep! Bleeeeeeeeeeeeep!!!!
  • schwarcw
    schwarcw Posts: 7,341
    edited July 2006
    The analog outputs of your DAC should go directly through your receiver by-passing their boards. You may have set set the inputs on the receiver to "Analog" on the input settings on your setup menu. Most separate preamps would receive the DAC output only in analog.
    Carl
  • joeparaski
    edited July 2006
    Ok...the little bulb just lit over my head. I'm going to run the DVD via Toslink straight to the pre\pro and the cdp will go through the DAC and then to the pre\pro analog inputs.
    This way, the LMC will decode the movie stuff (dts-dds-ddses-tph-rrs-tcby and any other letters that are out there)
  • steveinaz
    edited July 2006
    You're on it, doggone it. That is a good solution, and what I would do.
