SVS must see...
Grimster74
Grimster74 Posts: 2,577
edited July 2006 in Speakers
I've already posted this in the Subwoofer section but beings this is the Speaker section, I'll post here also. Looks like SVS is getting ready to add a new member to the family and it is "Small", check it out.
http://svsound.com/news-news.cfm
  • PolkThug
    PolkThug Posts: 7,532
    edited July 2006
    Argh! Please copy and paste, the corporate net nanny won't let me see!
  • Grimster74
    edited July 2006
  • Grimster74
    edited July 2006
    Measurements are 14"x14"x15" (HxWxD)
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited July 2006
    The little Von Schweikert I got goes to 20hz +/-2db but it retails for about $1500.00. This little SVS looks nice.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • Grimster74
    edited July 2006
    Here are the specs:
    -Proprietary SVS-built, high-performance 12" Plus woofer
    -425 watt BASH ® digital switching amp
    -CAD cabinet with 1" front baffle, glass lined
    -Single band Parametric EQ
    -Room compensation control, continuously variable phase
    -Full crossover with RCA, high-level or XLR inputs/outputs
    -Precise CNC-milled panel construction, hand-worked real wood veneer
    -Front-firing design with flush-fit baffle
    -Removable, compliant floor isolation points
    -Custom finish choices to match any decor (black vinyl, maple, oak, rosenut, black gloss)
    -Rigid grill, chrome pin or invisible “neo” attachment
    -Extra heavy-duty removable 8 foot power cord
    -Contemporary, "seamless" enclosure styling
    -+/- 3 dB 22 Hz-150 Hz or better (2-4hz deeper in small to mid-sized rooms)
    -Ultra compact: 14" wide x 14" high x 15" deep (with grill installed)
    -Weight: 40 pounds
  • shack
    shack Posts: 11,154
    edited July 2006
    "Front-firing design CAD cabinet with 1" flush-fit front baffle, glass lined."
    Interesting design. Viewing the pictures, at first I though it was a sealed sub.
  • wingnut4772
    edited July 2006
    Me too. I would like to hear this one. It would be great for a bedroom or apt. Ht
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
    VR3 Posts: 29,762
    edited July 2006
    That..is awesome looking. I bet it rocks.
    I like big subs though.
  • Grimster74
    edited July 2006
    It IS a sealed sub.
  • wingnut4772
    edited July 2006
    Grimster74 wrote:
    It IS a sealed sub.
    That's what I thought? They are quick.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • PolkThug
    edited July 2006
    thanks Grimster!
    Looks nice.
  • dkg999
    dkg999 Posts: 5,647
    edited July 2006
    I think I just found the sub to go with my Magnepan 1.6's! If the pricing is in the range quoted, it's not really worth building a DIY sub if this things any good.
    DKG999
  • Grimster74
    edited July 2006
    I'm already ready to pull the trigger on one for the upstairs rig.
  • tryrrthg
    tryrrthg Posts: 1,896
    edited July 2006
    Grimster74 wrote:
    It IS a sealed sub.
    Yep, SB = Sealed Box. I bet they're using an LT circuit to get that low end extension. The LT circuit is popular in the DIY crowd, and that is where SVS's roots are.
  • faster100
    faster100 Posts: 6,124
    edited July 2006
    when is it coming out? didn't see a date or pre-order
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • Grimster74
    edited July 2006
    Pre orders start in August, will not start shipping until mid September.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited July 2006
    I'll take two.:D
  • unc2701
    unc2701 Posts: 3,587
    edited July 2006
    Yeah, LT or they assume that you can use that parametric EQ to boost the signal to correctly counteract the roll off.
    Edit: I take that back- the room comp is probably the LT, then they've got the EQ on there to take care of your primary room null. Very nice design.
    Backburner:Krell KAV-300i
  • Shizelbs
    Shizelbs Posts: 7,433
    edited July 2006
    I'll probably get one. I like small subs.
  • faster100
    edited July 2006
    is rosewood the only color option, I did skim through the article just didnt see that either..
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited July 2006
    Put me down for 2 also. I wish the would do something sealed in an 8" model, with the quality of the drivers they use, you want to talk about attack, and speed - I can't imagine.
  • PolkThug
    edited July 2006
  • Shizelbs
    edited July 2006
    $700 for black.
  • dkg999
    dkg999 Posts: 5,647
    edited July 2006
    Maybe we should negotiate a CP group buy! ;)
    DKG999
  • mmcgehee
    mmcgehee Posts: 64
    edited July 2006
    That's an awesome lil sub there. Couple hundred more though and you can get the PB-12/Plus. So I'm still saving up for that. This is an awesome sub if you're limited on space though.
  • dorokusai
    dorokusai Posts: 25,661
    edited July 2006
    I was told about the prototypes in January...about damn time.
  • unc2701
    edited July 2006
    I think it's aiming for a slightly different market. The sealed design won't give you huge SPL's, but it'll be FAR more musical that your standard ported sub. It also doesn't hurt that it's so small :)
  • Shizelbs
    edited July 2006
    Being more musical won't be a bad thing for SVS.
  • unc2701
    edited July 2006
    Yep. The size & specs make me think of the Velodyne SPL1200... less power, and no auto EQ, but half the price.
  • MattN03
    MattN03 Posts: 558
    edited July 2006
    Nice looking sub. I really like the wood finishes :cool:
