S6 woofer glue
Jockos
The rubber surround on my S6 is coming undone where the surround meets the speaker basket. Instead of buying a new driver I would like to repair it. What kind of glue is recommend. Will rubber cement work? thanks for any help.
Jockos
Jockos
Post edited by Jockos on
Epoxy.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
2 part epoxy? I was on parts express and they had a speaker repair glue how's that?
Thanks,
Jockos -
That would probably work fine. Most manufacturers use a cyanoacrylate adhesive, which is a fancy name for "crazy glue". although I would like to think it is of higher quality.
Of course if they have foam surrounds, don't go near it with crazy glue, it will melt the foam. -
Thanks; I used super glue and that seems to have worked. Seems like the adhesive is coming apart on all the drivers. It is very dry and brittle. The S series drivers have an unusual design; the rubber actually goes over the basket and there are 4 rubber pins molded into the surround that fit into the steel stamped basket, seems like a production gig to save time. I think epoxy would have been stronger but thats a longer project for next time. Seems like no one ever talks about the S series.......... Anyway Thanks for all the advice
