db212-2?
adampoity
i was thinking about gettin db212-2 and i dont know that much about subs and amps so i was wonderin if anyone can give me some advice on wat they think i should get for these subs thanks for your help.
Post edited by adampoity on
The db212-2 is an awesome box. It is fairly large though, so make sure it fits into your vehicle. Also, you need an amp that can drive a 2 ohm load, if you like it loud we'd recommend around 500 watts into 2 ohms continuous.-Eric
-Polk Audio
