Advice wanted...
Grimster74
I'm sure I've been down this road before with you guys but I'm really interested in getting a 7-channel amp for my setup downstairs but with so many on the market, not sure which one to choose. I'll be using my Denon 3805 as my pre/pro, I really like the interface on the Denon which I plan to keep for a while. Anyways, my budget I would like to keep between $1000-$2000, the lower end more preferable. The amp thats caught my eye is the Outlaw 7125 which is 125w x 7. My question about this amp is this the actual wattage with all channels driven or is it actually like 85w x 7, if so I'd probaly be better off just sticking to the receiver. Any and all advice would be greatly appreciated.
Post edited by Grimster74 on
Here's a great 5-channel option: http://cls.audiogon.com/cgi-bin/cls.pl?ampsmult&1154804030
You can either use the Denon for the rear speakers or buy a 2-channel amp and you'll still be well within your budget.
Don't forget to factor in at least $200 - $300 for cables.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
PM sent
Casey
H/T: Epson 6500ub
Sony UBP-X800
Toshiba HD-XA2 (HD-DVD, CD)
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi 10 (bi-amped)
Polk CSi5 (bi-amped)
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
TV Rig: Samsung 50'' 4k display
Polk Signa-1 Surround bar -
Okay Millerman, can you give me some impressions on the 7125. Should/would it be worth the purchase or should I invest the money elsewhere?Money Talks, Mine says Goodbye Rob!!!!
well I can't tell you yet Fed-ex has my 7125 out for delivery right may be in a day or two after I fool around with it alittle.
oh, and did you click the about/gallery link on the outlaw web sight thats where it talks about the watts and specs, but I couldn't get the link to work.Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
In my expericance the thing that makes the biggest difference (after speakers) is getting as much current to your speakers as possible. This means having good or multiple power supplies....
Here is what i would do. Use your receiver's amp for the surround speakers only.
Buy a good 5 or 7 channel amp. Then use this amp to biamp the left, right, and center channels. If you buy a 5 channel amp, then only biamp the left and right and use the last channel for the center.
The 7 channel you are looking at looks good. Might want to consider buying a used outlaw online with more power. After all, the better the power supply and transformer, the more dynamic your sound will be.Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
Amps & Power: Rockford Fosgate T8004 x 3, Cascade Audio APS-55 power supplies x 5, and 1 farad capacitor.
Electronics: Denon 3806, Toshiba HD-A1, & Sony KDL46XBR2
Accessories: Anti-IC interconnects, 8 Mondo Traps from Realtraps, and Salamander furniture. -
I really like my Sherbourn 7/2100, like this one.
It works great and is built like a beast.
It does get warm though and does not double power @ 4ohms.
My next amp is going to be a Sunfire Cinema Grand when I can come up with the proper coinage.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
I have owned a couple of Outlaw amps in the past and they are a great value for the money.
Actually , I forgot, I still have Outlaw monoblock amps and they are great.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
I am using the Outlaw 770 (200watt x 7channel). I have no complaints with it or the company who has shown great service.
So that you can see the quality, I have provided links to pictures of the inside of the 7125amp and the 7500 amp. Good luck with your purchase.
Pictures... http://www.prillaman.net/outlaw_pics/Holydoc (Home Theatre Lover)
__________________________________________
Panasonic -50PX600U 50" Plasma
Onkyo -TX-NR901 Receiver
Oppo -Oppo 980HD Universal DVD Player
Outlaw -770 (7x200watt) Amplifier
PolkAudio - RTi12 (Left and Right)
PolkAudio - CSi5 (Center)
PolkAudio - FXi3 (Back and Surround)
SVS - PB-12/Plus (Subwoofer)
Bluejean Cables - Interconnects
Logitech Harmony 880 - Remote -
Grimster, while I'm sure the 7125 would be fine, I would go for the 7700 just to have the extra power. That way you will probably never have to be concerned about having enough power ever again.
It is always better to have more than you need, rather than not enough.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
I just got word that some Outlaw audio amps and other products will be increasing in price come July 1st 2006. so anyone teetering on an Outlaw Audio product may want to move on it before the end of the month.
PolkFest 2012, who's going>?
cfrizz wrote:Grimster, while I'm sure the 7125 would be fine, I would go for the 7700 just to have the extra power. That way you will probably never have to be concerned about having enough power ever again.
If you're considering pushing your budget with the 7700, you might want to consider http://www.bkcomp.com/ref200_57.asp
I saw the 200.7 reduced to around $2100 at magnolia yesterday. Maybe you can get them cheaper elsewhere for even less... -
B&K 7270 (basically the same as the 200.7):
http://cls.audiogon.com/cgi-bin/cls.pl?ampstran&1155091029
And i just noticed that it's in my zipcode... Let me know if you want me to go check it out.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
danger boy wrote:I just got word that some Outlaw audio amps and other products will be increasing in price come July 1st 2006. so anyone teetering on an Outlaw Audio product may want to move on it before the end of the month.
DB is right on the money. From Outlaws newletter:Price Increases
As we first announced in the Newsletter that was sent out prior to the Home Entertainment Show, we have had numerous price increases from our suppliers in the past year. Higher prices worldwide in the costs for basic commodities such as steel and copper, along with the higher shipping costs caused by the dramatic increase in fuel prices, have become a fact of life in every part of the economy. We have been able to absorb most of those price changes up until now, but we regret that we can no longer hold the line on the pricing for some of our amplifiers. The amount of metal used for their transformers, heat sinks and chassis makes them vulnerable to price increases of these raw materials.
For that reason, effective July 1, 2006, we are forced to increase the pricing of our 5x200 WPC and 7x200 WPC amplifiers. (Pricing for the Model 7075, Model 7125 and Model 2200 remain the same, as their prices were set more recently and have not undergone the price pressure of their larger brethren.) We are letting you know about these increases in advance, so that there will be time to consider making a purchase before the new prices become effective.
The 5x200 WPC Model 7500 will carry a $1,599 price tag starting on July 1st, a modest $100 increase. The popular Model 990/Model 7500 combo price increases $100 to $2,498.
The Model 7700 price will increase to $2,149. Even with this increase it remains the most affordable 7x200 WPC amplifier with balanced inputs available today, a clear value when compared to anything in the market. The popular Model 990/Model 7700 combo package will be priced at $2,998, an increase of only $100 over the current price.
The Model 7200 is now available at the $1,849 price announced at the Home Entertainment Show. This 7x200 WPC powerhouse is perfect for those who will not make use of the fully balanced architecture of the Model 7500 and Model 7700. For those of you not familiar with the 7200, a production unit is now being photographed and complete information will be posted in the 7200 forum in the saloon next week.
In addition to the processor/amplifier packages just described, we continue to offer a wide range of combo package values that combine our full range of amplifiers, processors, subwoofers and the amazing Velodyne SMS-1.
Pricing for our other products remains the same as currently listed, with the exception of the Model RR2150.Holydoc (Home Theatre Lover)
Well I just got every thing hooked up and balanced out, as far as if you should purchase or invest elsewhere I really don't think that I should be advising you on that since I have never heard a 3805 or any other Denon for that matter but I can tell you that my HK vs my HK & the Outlaw the HK & the Outlaw win hands down. You hear people talk about the sound being more dynamic the sound stage being wider, well let me be the frist to tell you I don't know a damn thing about any of that, all I know is that it just sounds better. The highs and mids are cleaner and the bass response is much tighter. So I'll say for me the money was well spent. I am now a beleiver that seperates are the best way to go!:)Grimster74 wrote:Okay Millerman, can you give me some impressions on the 7125. Should/would it be worth the purchase or should I invest the money elsewhere?Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
Thanks Millerman, I'm still doing some research on amplifiers but I have an idea that what ever amp I get may be from Outlaw Audio.Money Talks, Mine says Goodbye Rob!!!!
Okay, I've narrowed my amp choice down to two amplifiers but not sure which one to go with. The first one of course is the Outlaw 7125 and the second is the Adcom GFA-7607. Anyone know whats the main difference between the two other that price. The Outlaw can be had for $1000 and the Adcom is $1700. Is the Adcom worth the additional $700 or am I going to get the same bang for the buck for $1000. Any help would be greatly appreciated.Money Talks, Mine says Goodbye Rob!!!!
buy two Outlaw 7125's and bi-amp all your speakers.Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
I like the Adcom sound(more tube like) but I'm sure both work fine.SuperDave
Yamaha RX-V992 (Center,Rears)
Adcom GFA-5500 (Mains)
Denon DVD-1920
Mitsubishi 40" LCD
DirecTV DVR Whole House
Polk LSi25 Mains
Polk LSiC Center
Infinity RS1 Rears
Monster THX Cables -
Forget the Adcom... its $700 more! Save the $700 or buy yourself the 7200! Its 200wpc and only $100 more than the adcomeTerps Swimming!
HT Setup
TV: Vizio VX32L
Reciever: Pioneer VSX-D914
HD-DVD Player: Toshiba HD-A2
Fronts: Polk R50s
Surounds: Polk R30s
Center: Polk R20's
Subwoofer: SVS 20-39PCi
2CH Setup
Integrated: Onix SP3 Tube
CD Player: Sony CDP-CX355
Speakers: Onix Strata Mini in PR Finish
Signal Cable: Classic Speaker, Analog 1 IC
Headphones
Grado SR 60, Bang & Olufsen A8, Shure e3
Other Stuff in Use
Onix xls, Dual Onix x-subs, Onix Ref .5, Dahlquist M903, Teac A-1D, Marantz 1060 -
At least take advice fom someone who has one.....(Outlaw or Adcom):D
Oh yea, maybe listen to them. You will be the one who has to live with the sound, for a long time.SuperDave
Denon DVD-1920
Mitsubishi 40" LCD
Polk LSi25 Mains
Polk LSiC Center
Infinity RS1 Rears
Sorry dude,Adcom sounding tube like??????????Ya need to get out more!:)SuperDave wrote:I like the Adcom sound(more tube like) but I'm sure both work fine.HT SYSTEM-
lsi 9's -
tonyb wrote:Sorry dude,Adcom sounding tube like??????????Ya need to get out more!:)
Gotta agree with tony here... I can only think of a few amps that are LESS tube like than Adcom.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Compared to Outlaw:o
I thought the Adcom sounded less harsh thats allSuperDave
Denon DVD-1920
Mitsubishi 40" LCD
Polk LSi25 Mains
Polk LSiC Center
Infinity RS1 Rears
Well, after a couple weeks of researching, looks as though I'll be placing my order for the Outlaw 7125 amplifier. Seems as far as bang for the buck, Outlaw is the way to go as well as CS also. I can't wait to get it ordered and get it downstairs so I can get it fired up. Is there anything special I need to know about hooking up a external amplifier. I know the first thing I need to do is rebalance my speakers but as far as settings in the receiver, do I have to turn internal amps off, etc. Thanks for all your inputs and advice.Money Talks, Mine says Goodbye Rob!!!!
Grimster74 wrote:Well, after a couple weeks of researching, looks as though I'll be placing my order for the Outlaw 7125 amplifier. Seems as far as bang for the buck, Outlaw is the way to go as well as CS also. I can't wait to get it ordered and get it downstairs so I can get it fired up. Is there anything special I need to know about hooking up a external amplifier. I know the first thing I need to do is rebalance my speakers but as far as settings in the receiver, do I have to turn internal amps off, etc. Thanks for all your inputs and advice.
you would hook up the Outlaw amplifier from your receiver with the pre amp outputs. the pre amp outputs on your recevier does not use the internal amps.. so you don't need to turn off any internal amps.
what receiver are you using?PolkFest 2012, who's going>?
Even if you dont use the internal amp in your receiver, it will still pull lots of current from the wall because of how it is designed (unless you can turn it off somehow). The more you turn up the volume, the more current it will pull. If you don't have any speakers hooked up to it, it will have to release this energy in the form of heat.
If i were you, i would use your receiver to power a pair of rear speakers and then use the extra connections on your external amp to bi amp the left and right speakers.Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
sickicw wrote:Even if you dont use the internal amp in your receiver, it will still pull lots of current from the wall because of how it is designed (unless you can turn it off somehow). The more you turn up the volume, the more current it will pull. If you don't have any speakers hooked up to it, it will have to release this energy in the form of heat.
1)Ok, first off you should be able to turn off the mains amp. Most recievers have an "A" and "B" button. If you turn off both, those will be totally shut down/ out of the loop.
2)The denon is probably a class AB amp. Meaning that if it's not pushing anything, then it's only going to use power for whatever the class A bias is- which will be constant.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Danger Boy, I'm using the Denon 3805 receiver.Money Talks, Mine says Goodbye Rob!!!!
Hmmm... ok, I'm not seeing the option to completely kill the power to the mains (some have it, some dont'), but you'll be fine running the Denon as a pre.
You probably won't even have to rebalance the speakers- the Outlaw's channels will be matched and all the adjustments you've done will be reflected on the signal levels on the preouts. You might have to tweak around with your sub, but that's it. Plug & play, dude. (Just don't power on until you're done with the plugging part).Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
