SDA-1C side panels coming loose.
honestaquarian
honestaquarian Posts: 3,186
edited June 2006 in Vintage Speakers
I KNOW this is a somewhat common problem.I just do not know how to fix it.Anyone with experience and suggestions about it?
Post edited by honestaquarian on
    F1nut Posts: 49,836
    edited June 2006
    Liquid Nails and clamps should fix you up.
  • ESavinon
    ESavinon Posts: 3,066
    edited June 2006
    Remove the panels,use a hair drier to warm the old glue, remove the glue with your hands by pulling it.any residue left can be removed with a spatula.
    Go to a craft shop a buy a large bottle of MAGNA TAC 809 permanent adhesive (large bottle is 8oz and cost approx $6.00).
    Apply a bead of glue around the perimeter working torwards the middle.wait 3-5 minutes then attach panels to speakers. Do both panels at the same time.
    Once panels are attached,have 4 sections of laundry rope long enough to encircle the speakers precut and tie each section around the speaker as tightly as possible. make sure the ropes dont damage or kink any if the drivers.
    Let the glue set overnight.
    The website of the adhesive manufacturer is: www.beacon1.com
    btw, make sure you use alot of ventilation when applying the adhesive otherwise you'll get a wicked high.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
    SCompRacer Posts: 8,353
    edited June 2006
    If they are bowed too badly to simply reattach and you need to remove them completely, see this thread, post 8.
    I had to recover some SRS 2's I purchased in [url=http://www.polkaudio.com/forums/showthread.php?t=29915&highlight=sda+srs+recloth[/url] this thread.[/url] I was able to get two side panels off without damaging them, but two broke requiring replacement. I used Liquid Nails to glue them back on. I applied a full perimeter bead with a series of X's from top to bottom.
  • honestaquarian
    edited June 2006
    Thanks guys.I will try SOMETHING sooner or later that you all suggested.
  • schwarcw
    schwarcw Posts: 7,328
    edited June 2006
    Make sure to do the wicked high thing too!:D
    Carl
